***C.E.L. 21 & 22 VTEC code***
Old Oct 18, 2010 | 08:53 AM
agomez913's Avatar
Default ***C.E.L. 21 & 22 VTEC code***
ok well i jus finished swappin a b16 into my hatch and its running and all but i have a CEL reading codes 21 22.... which are the vtec spool solenoid valve and the vtec oil pressure sensor....so i took the whole vtec solenoid peice off that bolts to the head and cleaned it out, put new gaskets on both the top and bottom and bolt it back...i ran the CEL again and it still came up....should i get a new oil pressure swith(the green peice) and vtec spool valve (upper peice were solenoid goes) ooorrrr jus bypass the codes?????? I NEEEED TO KNOW ASAP..IF VIEWED BUUMMP
TR "Eg6" Crew #14
1993 eg hatch-totaled
1992 eg hatch-(D.D.)
Old Oct 18, 2010 | 09:26 AM
BoostedRacerDad's Avatar
Pops
I wouldnt just start replacing parts yet.
Pull the one wire plug to spool solenoid ( so it is not connected to ECU wiring )and measure with ohm meter to ground. It should be about 15 ohms. You can also run 12 volts to it and see if it clicks. This will prove your solenoid is good.
On the green plug(pressure sensor) bring up to operating temp and measure resistance across the the pins and you should get anything other than open.
You might need to check your pinout from ECU next then make sure you are getting oil.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Oct 18, 2010 | 09:42 AM
agomez913's Avatar
thanks bro ill try it and ill let u kno
TR "Eg6" Crew #14
Old Oct 18, 2010 | 10:05 AM
Pops
Use this for pinout
Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28
JoKie TuNinG
StricKlyMT
727-510-6301
Old Oct 18, 2010 | 10:44 AM
flatrex's Avatar
crx hatch sedan
Boosted has good info. I take it the motor fit well with the new mount bracket.
Old Oct 18, 2010 | 11:51 AM
agomez913's Avatar
^yea bro fit iin nice..i should b giving u a call soon about that quarterpanel peice
TR "Eg6" Crew #14
Old Oct 18, 2010 | 11:58 AM
agomez913's Avatar
u want me to pull the wire that plugs to the solenoid and run 12 v to c if its good????
n how exactly do i check the green 1?
TR "Eg6" Crew #14
Old Oct 18, 2010 | 04:03 PM
flatrex's Avatar
crx hatch sedan
Glad to hear that. Just hit me up when you want that done
Old Oct 19, 2010 | 07:36 AM
Pops
Exactly, unhook solenoid and power with jumper +12vdc and see if it clicks which will indicate coil does indeed work. Or with Multimeter set on Ohms go from that same one wire to the block(ground) it should read 14 to 30 ohms . If meter says O.L. the coil is open and no good.
The green plug (vtec pressure switch) can be checked by unpluging it and you will see two prongs in side. With meter set on Ohms place the meter leads one on each prong with the car off should read about .2 ohms. that means continuity if it reads O.L. (open it is bad and needs to be replaced)
Now since you have the meter out,
1. unplug the two wire clip to green plug
2.with the key on but not started put one lead of the meter(set to DC volts) to the blu/black wire and other to block it must read 12 volts
3. Now put leads on blu/black and black it must still read 12 volts. If it no longer does the black wire( which is ground is no good)
Got it all? LOL peace
JoKie TuNinG
StricKlyMT
727-510-6301
Old Oct 19, 2010 | 08:36 AM
agomez913's Avatar
thanks bro
TR "Eg6" Crew #14
