PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
  1. ls intake fit gsr?
  2. sleeve block and block gaurd?
  3. what to look for when buying a v-tec head!?
  4. 1990 civic 4 speed manual trans
  5. stupid question...
  6. jdm front end
  7. Tire size question
  8. TQ for the 2.0 FI
  9. need a techy !
  10. Fuck Acura`S
  11. Susp Questions
  12. Adjustable KYB AGX Settings
  13. New Acura NSX (hsc concept) pictures :-)
  14. question for siR stuff
  15. clutch ?
  16. hey anybody know angel eyes?
  17. sinlge cam question
  18. Turbo & Nitrous...
  19. is it normal?
  20. 96-98 civic rear disc conversion
  21. need to rebuild tranny...where to get parts?
  22. intake manni
  23. mini me
  24. cam questions
  25. Where Can I Get Swap Guides
  26. Hcp Or Hasport Motormounts????
  27. Help with tires....
  28. black spacers on valve cover
  29. Vtec sohc head
  30. SAFC or VAFC
  31. any welders out there?
  32. ECU help!!!!!!!
  33. Smoke out exhaust ???????????
  34. RWD Teg
  35. power window/locks on 96 cx hatch
  36. total JDM
  37. new ? for 3rd gen accord
  38. balancing the bottom end
  39. exhaust rattles
  40. 2 and 3 step selector
  41. boost controller problem
  42. Need Help with RPM Activator switch to VTECH
  43. another question
  44. question
  45. Dumb Question Need A Quick Answer
  46. Need Help
  47. Wiring EcU harness
  48. Whats better a d16z6 or a d16y8 ?
  49. Fuel Pressure?
  50. Sohc Turbo or Dohc N/A???
  51. Question about motor noise
  52. Bumper?
  53. anyone own/work at a shop??
  54. JDM H22 distibutor cap?
  55. 15B Vtec Wiring Help
  56. Serious swap inquiry?
  57. ls in del sol?
  58. Will 215-45-17 fit a Civic?
  59. LS/vtec compression ?
  60. Next crazy Honda swap....
  61. Shift linkage assembly...a warning
  62. LS/vtec Frankenstein
  63. dual point to multipoint injection need help
  64. custom exhuast
  65. sohc vtech turbo
  66. Question of all Questions---Honda Tech x10
  67. vtec kinda quiet??????
  68. Considering Another Hatch, a few quick questions....
  69. 89 teg question
  70. Torque Specs
  71. fuse keeps going out..
  72. 91 integra tanny on first gen b16
  73. 96 gsr center console in ef civic?
  74. dizzy ?
  75. vtec hookup
  76. engine starter problem
  77. SOHC Pistons question?????????????????????
  78. Superchargers : How WHy and yes a turbo is one too
  79. grill mesh
  80. need help wireing my car!!
  81. Engine probs
  82. Ls wiring harness questioN?????
  83. Need help thinking...
  84. LS turbo
  85. new acura front bumper(93-up)
  86. Difference between USDM H22A1 and JDM H22A (PICS)
  87. Please Help! What kind of rod is this
  88. any other s2000 owners?
  89. putting a OBD0 head on a 92 hatch
  90. boed or charged?
  91. How much would you think..
  92. head lights
  93. stuck in gear
  94. vafc
  95. shitty dyno sheet.
  96. mesh grilles?????
  97. GSR and LS parts question?
  98. vtec head swap ?'s
  99. isn't this pretty? or at least better
  100. OBD1 Dizzy
  101. skunk2 ecu
  102. What model CRX?
  103. h22 axles
  104. mini me?
  105. Valve cover?
  106. Swap Problems - need some help
  107. navigation in an EK?
  108. ls vtec?
  109. break in time
  110. ac messed up
  111. idle problems?
  112. fix a flat?
  113. honda cd player ..
  114. Running "Rich" ? could use a lil info
  115. Installing VAFC
  116. Honda parts website? Link?
  117. new piping ? for H/A Techies !!!!!!
  118. Fine tuneing,does it include Valve adjusting?
  119. how much tranny fluid for a ys1
  120. why does it do this?
  121. need some serious info quick???
  122. how much oil do i need
  123. Problem starting my car...
  124. damn look at this
  125. Need An Integra!!!
  126. spun bearing on the civic
  127. help w/ the homemaid individual throttle bodies
  128. got in a wreck today...not tech
  129. ----aluminum dashes??????-----
  130. turbo/nos
  131. I Need Help
  132. shaving cylinder head
  133. Edelbrock coming through ?
  134. Question for u honda gods
  135. Brake kit help
  136. supercharger w/nitrous is it safe?
  137. my shocks are gone what now?
  138. SOHC VTEC w/NITROUS???
  139. need help
  140. NEED HELP want to swap b18c into 98 civic ex ?
  141. bye bye tranny?
  142. Old School Mechanic Wanted
  143. ZEX CAM? yes or no
  144. lucas 440 install question
  145. How to aim 98 civic stock headlight?
  146. NEED 92-95 Hatch ASAP CAHS IN HAND
  147. 88 CRX Swap HELP!
  148. what axles to use?
  149. Where and how much ?
  150. My GSR won't work and don't know why...any ideas?
  151. vafc question
  152. Questions on my 98 civic
  153. Questions about a ls swap
  154. Help - mechanical '04 s2000 questions - serious inquiries please
  155. b17a build
  156. k series?
  157. Best for ls/vtec
  158. ACT Clutch Quest.
  159. integra auto to manual
  160. turbo questions..
  161. throttle body and injectors...
  162. need "mechanic"...wanna make some $$$?
  163. Certificate of Distruction / Salvage Title?!
  164. combustion chambers and sprockets...
  165. Will these motor mount inserts work?
  166. Exhaust
  167. aem fpr inline/offset
  168. install help..
  169. venom control module
  170. turbo or supercharger?
  171. hondata intake mani gasket install
  172. check your work don't let it happen to you
  173. Cold air F@*k up!!
  174. Quick Question????
  175. Ingalls Camber kit
  176. need help
  177. h22 #3 problems?
  178. polishing valve cover
  179. snapped timing belt
  180. Prelude Meet, St. Petersburg, FL
  181. Exhaust question????
  182. quick Q
  183. What do i need for this swap
  184. Valve Spring Compressor?
  185. cleaning
  186. Turbo Ls Questions
  187. Ls/Vtec is done! But in need of a starter (hint) :-)
  188. how to
  189. tranny question
  190. compression with supercharger????
  191. Car smokes worse!
  192. << Tampa Racing Presents Track Event # 7 >>
  193. Rainbow looking headlights like a bubble???
  194. Which goodyear rubber should i go to clearwater or st. pete?
  195. h22 and h23 ?'s
  196. lowering question
  197. I Need Some Help Please
  198. integra auto to manual
  199. need help
  200. Just got my JDM type R in my 95gsr
  201. next h/a meetup?
  202. OBD2 Question
  203. Car Smokes above 4 rpm
  204. Engine spec list
  205. how do you change the throttle cable??
  206. body kit squeek...
  207. turbo
  208. 2 quick questions
  209. oh man..
  210. **need help w/ vtec problems******
  211. seats.
  212. turbo LS dyno
  213. The Beast is gone.
  214. porting intake mani
  215. New CRX?
  216. suspension ?
  217. tranny & clutch ?
  218. is this fake?
  219. sorry to keep on asking
  220. radiator support?
  221. Good Exhaust Shop
  222. battery drainage!
  223. Anyone here rocking a K series?
  224. Custom Stainless Lines Made?
  225. Quick question ..
  226. HKS filter vs. K&N filter
  227. h22 rebuild
  228. Tire Pressure ?
  229. CRX, Doesn't like running right (Again)
  230. need wirning help
  231. over heating prob.
  232. brand new nos kit for trade
  233. dsm turbo on a d16
  234. forced induction questions
  235. tach problems
  236. Lips for a Rex
  237. Valve Removal Tool
  238. Should I?
  239. will it fit?
  240. Need Help!!!!!!
  241. Turbo Parts
  242. where to go to polish rims
  243. armrest for EG
  244. Car Value
  245. track time question?
  246. B17a1 Plans
  247. engine code
  248. Over Heating
  249. Please HELP!!!!!!!!!!!!!!!!
  250. crx hf w/90-93 integra swap
