OBD2 Question
Old Mar 4, 2004 | 11:31 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Default OBD2 Question
Will a OBD2 USDM GSR run properly without a catalytic converter? I'm swaping a it in my '97 hatch and I don't have a cat.
Old Mar 4, 2004 | 11:35 AM
qitstrn's Avatar
Can you spot me 20 cars?
You need to buy/build a test pipe. A test pipe is a pice of exhaust that has an O2 bun welded in to it so you can run your O2 sensor. You need to run your O2 or you will have a check engine light. Tucan industrys makes a nice test pipe that is a direct bolt in to replace the cat. It sells for about $65 and is stainless.
Old Mar 4, 2004 | 11:38 AM
already have the test pipe taken care of. I'm just worried about the second O2 sensor(after the cat) throwing the ECU in limp mode.
Old Mar 4, 2004 | 11:46 AM
mtber's Avatar
You can trick the 02 sensor by hanging it in the engine bay if you dont have anywhere to thread it into.
IMO, I would get a 02 bung welded into the exhaust test pipe/system or just get an obd1 computer
Old Mar 4, 2004 | 11:53 AM
will it run right with an OBD2 ECU without a cat? if I put the after cat sensor in the exhaust it will throw a code and it might not run right. thats why i'm trying to find out if i need to put a cat on it cuz i already have it. i just dont want to if i dont have to.
Old Mar 4, 2004 | 01:06 PM
mtber's Avatar
You dont need a cat for it to run correctly.
Old Mar 4, 2004 | 03:22 PM
ok thanx
Old Mar 4, 2004 | 03:52 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
what the hell is a catalytic converter???
JK
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 4, 2004 | 05:01 PM
integrakev78's Avatar
(Torqueless Wonder)
Switch to obd1 or get a highflow cat or get an 02 simulator
