OBD2 Question
Let me boil it down for you guys that are lost.
A 96-00 civic hatchback has the cat in the HEADER area of the exhaust system.
Traditional car:
Exhaust =====Cat=Header=Engine
Ek:
Exhaust========(Header/Cat in one)=Engine
A dohc swap in an Ek bolts right in using the proper mounts.
The exhaust systems for the ek will usually bolt up to a dohc swap with a little tweaking of the hangers etc. (ls/b16/type-r & some gsrs)
Note: The dohc header only has 1 02 bung because dohc cars usually have a cat right after the header.
Hanging an 02 sensor in the engine bay worked for me when I used to run my JDM obd2 ecu in my ek with a factory ls swap.
I have also seen this trick work in a obd2 turbo sohc civic of my friends.
It may not be the best solution but it prevents a cel
IMO, get a obd2 to obd1 conv harness & a obd1 chipped out p28.
It will solve this issue & it will enhance your performance.
Traditional car:
Ek:
you really should go obd1 and then you won't even have to worry about it
www.artofspeedproductions.com
A cel = strain on the MIL indicator bulb!
Hence pulling the bulb until MIL is repaired is the solution.
lol j/k
lol j/k
moma always said
MILS ARE FOR THE DEVIL!
that .012 horsepower could be increased to .5 hp with good tuning which could help you drop .00001 second off your 1/4 mile..... come on now guys
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
