lucas 440 install question
Old Mar 9, 2004 | 10:14 AM
MoparNeonSRT4's Avatar
Default lucas 440 install question
im installing lucas(same as rc0 440cc injectrors) into a 95 civic ex turbo and i ran into a problem. the bottom of the injector doenst seem to fit into the manifold.... is this a normal problem and if so will boring out that bottom o ring allow it to fit? does anyone have pix of their rc/lucas injectors on the car already so that i can see how they are supposed to fit in there cuz i was told that they are supposed to stick out a little bit...
Old Mar 9, 2004 | 11:04 AM
ghuey's Avatar
member
The rc injectors do not fit down in to the manifold. If you bought them new read the instuctions it will explain this.....
Guy
AE
The world's a cold place; better pack your own heat.
Old Mar 9, 2004 | 09:32 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
You have to modify the O-Rings to make them fit properly... Just make sure to check for leaks....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
