ac messed up
Old Mar 11, 2004 | 03:05 PM
blazin85's Avatar
Angry ac messed up
For some strange reason my air only comes on when i turn it up to high. When i put it on the other four nothces the air does not come out. Is this fixable or am i just stuck with this problem. Somebody help pleez!!!!!!!!!!
Old Mar 11, 2004 | 03:06 PM
Josh's Avatar
Dr. Doom
do a continuity test on the switch....if the switch is bad, replace it.
Old Mar 11, 2004 | 03:53 PM
1fasthatch's Avatar
Traction Problems
it is most likely the switch the same thing happened to me and I just replaced the entire climate control and it fixed the problem
www.artofspeedproductions.com
Old Mar 13, 2004 | 08:17 PM
sone's Avatar
check blower motor resistor.....
Old Mar 13, 2004 | 09:00 PM
mtber's Avatar
Is your ac compressor clutch engaging when you turn the ac on ?
If not check your ac freeon levels, the system has a pressure switch...
Old Mar 13, 2004 | 09:13 PM
grumpyoldman's Avatar
zephyrhills
all of the above ... but i am adding this ... take a second or 2 and look at all of it and trouble shot and think why it wouldnt work (switch)blowermotor)
Old Mar 13, 2004 | 11:49 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
WRONG WRONG AND WRONG lol
Its the blower motor resistor ! check this check that !! lol simple shit here guys !!
Old Mar 14, 2004 | 08:37 AM
Josh's Avatar
Dr. Doom
well since you took a look at his car
same thing happened in my girl's mustang, replaced the switch, worked just fine.
Old Mar 14, 2004 | 09:01 AM
Shitstangs have the rewsistor in the climate control module 99.9% of cars wioth fan speed isues is the Blower Motor Resistor it just depends on where its located ! some are in the switch some are in the motor caseing Honda of which is located right above the fan case attached with 2 lil screws and a 2 wire plug sticking out of it !! any other questions class ?
