96-98 civic rear disc conversion
Old Mar 17, 2004 | 11:15 AM
i-VTEC2's Avatar
Unhappy 96-98 civic rear disc conversion
i am using the rear set from 94 integra. do i need to change the prop.valve and mastercylender?the propvalve is the same part #as the one found in the 97 acura TL
Old Mar 17, 2004 | 02:01 PM
mtber's Avatar
You do not "HAVE" to change anything besides your ebrake cables.
Just install the rear hub/trailing arm systems & run integra ebrake lines to your ebrake....
Bleed your brakes the proper way & you should be ok
The best prop valve for a rear disc setup is a 40/40 prop valve...
I say you try leaving the systems you have in place alone & run the disc setup with the proper ebrake lines. If you dont like it, just change out the prop valve later.
