crx hf w/90-93 integra swap
I'm no honda expert so don't take my word for it you'll prob need some motor mounts - hasport are the best from what I've heard; then you'll maybe need the 0bd1-0bd0 conversion - it's really not a hard swap buy why bother a guy here on tr was selling em for $600 or so installed which is cheap as hell he'd prob give you a hell of a deal on installation. check import parts for sale and search "ls swap" or something.
basically the complete swap engine trans ecu, linkage. If you pm 92'CXhatch(Keith) he can tell you for sure he knows all of that shit!! your going to need a mount kit prefable from hasport. Make sure the ls ur getting is a cable trans on it cuz I belive the rexes are cable not hydro. You need either axles made or even 90-93 teg axles is what I think ppl have used in the past.
United States Marine Corps
6322 Comm-Nav Tech
PFC
RAH!
6322 Comm-Nav Tech
PFC
RAH!
you'd need a mount kit (arizona, hcp, or hasport) and a modified shift linkage. If you have a '90-91 ls swap, then you can use the distributor and injectors. You can use your HF wiring harness or the ls, they're basically the same. If you have a '92-93, you'd need to switch out the distributor and injectors.
The most overused word to describe an import: CLEAN. Every f****** car is so CLEAN.
use the Hf Harness if Its an LS & it work fine as long as its LS use the injectors
from the LS & ECU also need a MAP Sensor for a Dx Si......
& get the hasport kit.!
813-377-5505
