exhaust rattles
Old Mar 16, 2004 | 11:09 AM
94lsteg's Avatar
BOOST IS BETTER!
Default exhaust rattles
I just put 2.25" piping on my 94 integra ls, and put on a RSX-s muffler.... The problem is, when in 2nd gear at high RPMs it has the rice rattle if you know what I mean..Is that b/c the resonater was taken out? any ideas? I want NO rattle..
Old Mar 16, 2004 | 11:10 AM
94lsteg's Avatar
BOOST IS BETTER!
the header maybe?
Old Mar 16, 2004 | 11:43 AM
spoonfed's Avatar
Tha numba one stunna
Yeah if you are running a straight pipe (meaning no resonator) you will get that ricey buzz in your exhaust sound you need a resonator to get rid of it.
... content in sig not work friendly
Old Mar 16, 2004 | 01:25 PM
Josh's Avatar
Dr. Doom
check to see that nothing is hitting your rear bumper also.....
Old Mar 16, 2004 | 02:17 PM
94lsteg's Avatar
BOOST IS BETTER!
Would the fact that I hollowed the cat have anything to do with it? ttt
Old Mar 16, 2004 | 05:08 PM
94lsteg's Avatar
BOOST IS BETTER!
which part of exhaust is the resonator...is it the chamber right after the middle hanger?
Old Mar 16, 2004 | 06:14 PM
Josh's Avatar
Dr. Doom
normally it's the canister right after the cat, if you hollowed out the cat this should give you a more raspy sound like you're describing
Old Mar 16, 2004 | 07:58 PM
spoonfed's Avatar
yeah it makes it worse too I have no cat...
Old Mar 17, 2004 | 02:45 AM
94lsteg's Avatar
BOOST IS BETTER!
so if i get a new factory cat will it get rid of it?
Old Mar 17, 2004 | 06:02 AM
JimmyHat's Avatar
Sphincter Say's What?
Um yea that has alot to do with it.
