balancing the bottom end
how high could you rev a d series motor if every thing was balanced and blue printed inside the block
thanx josh
thanx josh
josh
14.7@91 sohc all motor
josh
cams STRENGTH of valve train and rotating assy balance are all factors in redline !
a cam can only rev so high and the spring can on return so fast before you get terminal velocity and it floats a valve and says bye bye !
internal balance consists of : Crank, Crank Pulley, FLywheel, ROds, Pistons. Weighted and Spun to balance everything is matched to the lightest component.
Head Basicly is stronger valves springs to can spring at the rate of the cam and RPM of the Bottom end. Your RPM is determined by the Speed your internals can spin and they themselves can rech terminal velocity but usually never does you usually get something coming apart due to vibration or imperfect parts.
before integra nem says WHY are cams a factor well cams actually determine your powerband. If you rev it to iunno 8k and then if you rev it to 9k youll see a drop in power due to the cam the cam grind is specific in RPM. if your engine is turning at 9k rpm and your cam highend power is at 8 the cam and valaves cant increase in speed or frequency of the opeing of the valves then you dont get enough air and then you start loosing power or it stays the same. So reving higher doesnt always mean better performance unless you build it to rev that high for a reason. Longer duration cams can rev higher and longer than short duration and hihe lift cams. make since ?
i said VALVETRAIN which includes the cams.....this is maInly what determines redline although there are other elements of which you've convered. obviously you don't give others credit for what knowlege they may have.....don't go assuming things.
not to take sides but in a general since the cam or cams are part of the valvetrain. just because it is not attached to the valve doesnt mean anything. it still accuates the valves . if you buy valves they dont come w/ the springs and retainers but they are part of the valve train as you stated. i dont even see why this is being argued over?
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
You can say they are part of the valve train but they arnt they just actuate the valves that are in the valve train. no arhuement i was just explaing what involves rasing your rpm and why things in the head affect this as well as the bottome end compnents.
Originally posted by jdmef9
so how high can i rev the motor excluding the head.
