compression with supercharger????
out of curiousity if im at 11.6.1 comp ratio all motor can i run a jackson racing super charger can i run a 4.2 pulley on there safely? if not what would i have to do?
tamparacing.com
Tuning is everything if you do. I used to know someone that had this much compression and ran a S/C at the same time. However, he did blew it up while he was adding more timing on the tables via Zynde.
Anything is possbile but without knowledge of what the engine is doing, why bother with it.
Safe to stick with OEM rings and pistons for the best realible and longevity. Do you know anyone with 50,000 miles aftermarket component?
Originally posted by SEEKERone
yeah bert, i remember doing that. destroyed stock piston ring lands(actually melted the edge of pistons). i have learned alot about what can and cannot be done since then. high compression and a JRSC are a potentially volitiale mixture that will not last long without serious tuning.
Yeah, well, you live and learn.
Next time when you have the compression again, you'll know NOW on what NOT to do.
