need wirning help
Old Mar 1, 2004 | 11:19 PM
20whiteboy03's Avatar
Default need wirning help
i got a b16a3 in my civic with a 99 b16a2 wiring harness and a p2t ecu need help won't start im lost
Old Mar 1, 2004 | 11:48 PM
mtber's Avatar
What year is your civic ?
Is the p2t ecu from the 99-00 ?
1st, check if your getting fuel (listen for fuel pump)
make sure the "green plug" is plugged in near your ecu, this is a common mistake people leave these plugs unplugged causing issues..
Are you getting a CEL or MIl (check engine light) when you turn the ignition on double click ?
If so, check your codes & post them back.
Old Mar 1, 2004 | 11:53 PM
99 civic ex the green plug is plugged in and is getting fuel the p2t is double the size of the stock ex ecu and came with the swap
my car is like my girlfriend spoiled and sometimes a BITCH, but she always finds a way to make me wanna keep her
Old Mar 1, 2004 | 11:54 PM
also there is a check engine light but i dont know what the the code is
Old Mar 2, 2004 | 12:54 AM
mtber's Avatar
1st eliminate the codes.
Use http://www.hondaswap.com/forums/inde...howtopic=29806
It might be something as simple as having your map & tps plugs swaped w/ eachother.
Old Mar 2, 2004 | 08:32 AM
Default i
isn't there a little hand held computer you can buy to tell you the ecu codes also do you know if a 00 b16a2 harness will work on a b16a3 vtec?
Old Mar 2, 2004 | 09:02 AM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
Ive been helping him with this for a while and trying to get time to go look at it, he got ripped on a swap it is a Mixed OBD system someone swapped parts on the engine and nothing matches hopefully he did what i said and got the right parts. Its an OBDI engine, with OBD I dizzy and OBDII intake mannifold with the OBDII Si wireing harness. He tried splicing shit and it still wouldnt start. when me and nate get some time we were gonna run out there and try and get it started.
Old Apr 9, 2004 | 01:52 AM
got it fixed
Old Apr 9, 2004 | 10:08 AM
Jdm Civic's Avatar
What was the problem?
