Quick Question????
You don't NEED to, and if you are keeping your redline the same then you will be fine. If you plan on getting bigger cams later, or spinning higher then it's a good idea.
i dont htink youll see gains like your imagining...... probably not worth the money and effort right now. Build a bottom end or go boost. Save your money and do big stuff.
aol: GregTMFM
aol: GregTMFM
If you want to be happy in the long run...
Buy a USDM in the box type-r block from bert-o at gettel acura.
Shave your b16 head 20 thousands.
Buy portflow inners & itr outers from portflow.com
Buy skunk2 stage 1 cams & cam gears.
Retain stock retainers & valves.
Buy some hondata s100 & have it tuned.
and i need something to tun so i can put my vtec controller cam gears and fpr on.
