Fuel Pressure?
What Should My Fuel Pressure Be Set At With My Setup?
B7 Block
Y8 Head
Y8 Intake Manifold
GSR Throttle Body
CRX SI Injectors
I Have It Set At 37 PSI Now!
Any Info Would Help! Thanks!
B7 Block
Y8 Head
Y8 Intake Manifold
GSR Throttle Body
CRX SI Injectors
To find your best fuel pressure your gonna need to put your baby on a dyno
To tune your fuel pressure at the track you need to crank your fuel pressure up until you notice your trap speeds drop at the track
I personally just set it by ear, take the factory recommended setting & add 2 psi or so & drive the car then play with it and just feel out the performance from change to change you make etc...
Your really want to tune your fuel via a management system such as a afc controller or hondata.
A fuel regulator baisically adjusts wide open throttle fuel pressure.
Hence the need for a fuel controller & dyno.
i have a high compression mini me swap in mine and i keep it at 38. i'll bump it a li'l more when i go to the track. but until i dyno tune it and such, it seems to do fine there.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Originally posted by JimmyHat
I personally keep my psi set to 40 but I have high Compression.
...91 SMF SCCA
