- Nitto Drag Radials
- B Series Strokes...
- Exhaust work.. Pronto
- Crewing for the Kuhmo/Catz/Deeper Image Civic!!
- My car is falling apart
- Head work
- need a good clutch
- OEM GSR FPR
- need jdm HELP please
- Rebuilding B16...need your thoughts....
- SOHC VTEC CAMSHAFTS???
- lug nuts???
- Stumbles...then moves
- New Honda/Acura Question.
- Suggestions gladly welcome...
- motor swap
- 11.51 compression on 93 octane?
- Any all-honda all-motor guys here?
- Worth the cash?
- AC.......bleh! who needs it !
- Humming Noise
- Apex-i N1 muffler
- what cam is this?
- Automatic Transmission FILTER
- Trannie swap for 93 Teg
- B16A into 1990 Integra
- Alignment
- how much would..
- OMG....What a mess glad its over!!!
- An easy way.
- kill switch for gsr power door locks?
- brakes?
- 1.8 block on a b16?
- Repacking RAT Axles with grease...
- What will 18s do to the feel of my Acura 3.0cl ?
- what ECU do i have
- Just wanted to say thanks...
- swap questions for a crx
- What can I do to make a 93 Integra GS Fast???
- Venom 400??
- OBD1 ECU
- okay all you h/a gods...
- hit a broken semi tire
- Prelude shit...
- Vtec head swap HELP!
- suspension techniques rear swaybar
- mini me swap parts and prices?
- F-max
- where should i go for this
- Waiting sux.... so I .....
- intake / catback = void warranty?
- Oil Drain Plug
- 5 Zigen RIms...
- HELP
- WTF?
- Ive seen everything now a CR-NSX
- whats a REAL good tire for HX rim??
- fuel pressure
- Oil?
- Motor Swap for CRX
- HOW
- So my battery died..
- k series hybrid.
- Swaping out gears....
- Rev Hard kits....?
- Bought another Car...
- radio code
- Cd player problem
- pistons
- motor swap
- Need someone in sarasota to do motor swap and
- JUST NEED TO...
- dyno results stock ls
- pistons and rods for a gsr block
- has anyone every heard of
- important tranny question
- gsr brakes
- cams
- ITR sway bar on a EK????
- Benefits of ITR Cams......
- Civic Si #s?
- ITR or GSR exhaust on Civ EX???
- DC sport cam gears????
- WHY???????
- 2 minor problems
- Removing the Center dash on a 2000 Civic
- Which exhaust sounds better?
- What Should I Hope For??
- PRmount kit fitting us hoodline
- turbo info 4 00 EX
- How can I rebuild my Tanabe racing Medallion witho
- radio help?
- gutting the cat on my 91 si
- Resetting the ecu
- Prepping for nitrous...
- need to double check wireing
- vtec controller or programed ecu ???
- CAR DIED!! need ur advice as to what happened?
- Easiest Way
- help diff. between an jdm vtec tranny and h2.3
- B16 tranny quesiton...
- Lowering my CRX
- 1.6 sohc vtec gude head package
- CODE 23!!!!!!!!!!!!!!
- boaring a throttle body and intake manfold
- Where to find a Intake manifold?
- Fuel Line
- Intake manifolds
- spark plugs
- cometic headgasket
- GETTING A GREAT DEAL...
- JDM 4-1 or Comptech 4-2-1
- FMIC...
- Throttle Cable Install
- DOES IT MATTER...
- Turbo Cars
- Best place to find Used B16A2 Differential (or Mr
- Difference between B16A1 and B16A2 Blocks?
- speedo calibration
- b16a2 swap into 97 Civic EX...
- whats going on??
- Turbo setup for a...
- Aem CAI Si fit an EX??
- Tenzo R venturi??
- Distributor Benefits
- Ls Tranny???
- exhaust
- transmission flush
- Wiring issues...
- Electrical sources
- Del Sol Radiator...
- B16A (93-94 SiRII) into 99 Civic EX
- might sell my 1st gen crxSI b16....
- Accord with H22A swap...
- exhaust help please
- Exhaust question
- getting a turbo for my prelude
- GSR alternator
- Balancing a built engine question
- HELP WITH HONDA!
- Problems with install... (update)
- Coilover install
- Coolant Bypass
- Hmmmm ?
- Type R wheels; knock offs?
- How big of a Down pipe FOR???
- rsx type-s parts?
- Quality local tranny shop
- exh. header...hmmm????
- Wire-jump for aftermarket stereo on civic?
- wiring
- Finally off...
- typical 60 ft times for a 2000 civic ex
- Skunk2 Cam Gears?
- high reving
- I met th eall famous DynoMan last night
- Skunk2 Pics?
- i gotta hookup on DRAG
- 2 Questions....
- Such thing as .............
- squeeky brakes
- Understeer
- cool thing i learnedhahahhahh
- Installation Reccomendations....
- B&M and SAFC
- Leak down test
- Throttle Body Spring
- drag gen III kit
- help!!!!!!!!
- Closed loop or open
- b16a to vtec????
- Mini-Me setup?
- apexi AVC-R or blitz DSBC
- under the Accord LX valve cover...
- civic springs
- Will a 2000 Si exhaust fit.....
- AEM CAI problem
- whats everyones problem with me
- spoon n1 exhaust
- skunk2 vs itr intake manifold
- CR?????
- LS 5th gear into S1
- Suspension setup...
- what gauge cluster to use?
- 12s n/a setup?
- which one?
- wiring help with EK!!!!!!
- which engine?
- filter change?
- ball joints going bad?
- What do I need to...
- Flywheel resurfacing
- driveaxle help
- couple ?s
- best AEM prices?
- aftermarket receiver in civic???
- Transmission oil fro a civic
- Cold Air doesnt fit
- Previous post on valve adjustment discovery
- Apexi SAFC install on 94 LS Integra
- EX tranny
- Check Engine light/Test pipe...
- Just got a 92 INTERGRA.......
- Cold Air
- Type R trany in a GSR ?s
- tire size
- Threw a code
- John I need to get that...
- EK dx intake swap
- I HATE MY BRAKES
- 00 Si OEM Struts on 01 ITR
- Damn fuel shizit... Question....
- throttle body?????
- Parts specifically for B18C for B18B?
- 1157 light
- d15 head on d16 block
- Whats wrong with my Teg??
- accord coil overs
- No spark please help diagnose
- Ex shift linkage
- mirrors?????help
- gay ass windows
- jack point
- hi flo cat
- swap ?s
- TurboSi Video from last saturday!
- Tip for installing fuel related items...
- EX fornt sway bar
- 6G EX Owners need an easy favor
- SOHC transmissions
- Axle back exhaust
- Installed...
- exhaust bolts are seized on!
- JRSC on a 2000 ex coupe
- IACV problem?
- HELP!!!! Cheap 310s?
- SOHC ZC?
- rear main seal installation
- Reliability of Coil-Overs.
- more hondata BS
- Injen CAI?
- 92-95 amber corner lenses!?
- ZEX Cams
- Where can I find a.......
- RAPING ZONE!!!!!!!!!!!!!!
- hondata?? Plus who does the flywheel lightening?
- Honda rear swaybars
- CVs
- My brakes...
- ACT vs fidanza vs clutchmasters vs.......
