Automatic Transmission FILTER
does a 1995 integra LS AUTOMATIC TRANNY have a FILTER? and if so where in the hell is it? And how do you change it?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
AIM: jasonbadler
813.508.PLAN (7526)
most automatic (besides saturn) have an internal filter. you drop the fluid pan and change it. th enew filter will come with a new pan gasket. itll be the large pan under the tranny. not sure about honda trannies though...
RIP Tim. i miss you, buddy
I know what most cars AT filter should look like but under the tranny theres no pan. well atleast not one that I could see.
AIM: jasonbadler
813.508.PLAN (7526)
AIM: jasonbadler
813.508.PLAN (7526)
The only place a filter could be on that car is in line in the cooler lines. That is usually only if it was replaced with a remanufactured honda unit. Other than that just wipe the stuff off the drain plug magnet and refill with honda fluid.
No filter on honda automatic I have owned two and worked on a few....add an external and a tran fluid cooler while your at it wipe and fill
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
Originally posted by "Someone"
Originally posted by 93ex
Pan is on the side I belive and I dont think there is a filter I put an external one on mine.
