Del Sol Radiator...
Whats so good (other than the Cooling) about the radiator off a Del Sol. What model and what year is the best?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
AIM: jasonbadler
813.508.PLAN (7526)
Guest
Posts: n/a
yours is 14 x 7 and single core very small and a del sol / gsr is 26 x 17 much larger. the radiator will cost you 130 new and about 70 used. You will have to buy a new radiator cap. Also you will ahve to make custom mounts wich is easy to do.
Guest
Posts: n/a
Your radiator is not 14X7 its 14 inches wide but its taller than 7 inches but unless you drive an automatic civic you ahve a single core radiator 5/8 thick the del sol is the same dimension as the civic however it is 1 thick since its a dual core and only a small portion of the del sol vtec has the same radiator as the integra. The integra radiators is 26 long. You wont be able to use your ac if you go with the teg radiator the ac condensor will be in the way. You would pretty much need to redo the front bumper/radiator supports if you want to have an integra radiator and ac. If you take out your ac condensor there wont be any problem putting the teg radiator in. Best price I have found on the del sol radiator is http://www.radiator.com $119 free next day shipping (Fed EX before 10:00am) and lifetime warrenty they even sent a free bag of candy and I was able to use my old radiator cap. Also the del sol vtec radiator is the same as the Civic automatic radiators.
Robster
Robster
