Problems with install... (update)
Guest
Posts: n/a
Welp I have the Skunk2 Intake installed along with a 64mm throttlebody...
Of course it couldnt be that simple for me... The TPS was acting erratic and throwing codes all day... Then it worked fine for a good hr and GOD IT WAS AWSOME. Now of course it is fukin fried and thowing more specific codes at me... So I now know that the TPS was the problem...
Codes:
Trouble Code - 16 (Fuel Injection Circuit)
MIL Code 7 - TPS Circuit Low Input TPS Circuit High Input Throttle position higher than expected Throttle position lower than expected
Fukin electronics...
Gonna do my best to find a replacement.
Codes:
I wish that I thought it would be that simple. The TPS worked for a good hour and then it farted out that scares me. If I set the voltage correctly it might simply screwup again but this time nowhere near home.
Voltage for the Acura Integra TPS:
Throttle Fully Closed - .5v
Throttle Fully Open - 4.5v
Buying a voltmeter today...
Then I am gonna adjust it... Both Vernon and I simply think its just out of the spec window by a little bit...
Should be good to go tonite.
Do not store up for yourselves treasures on earth, where moth and rust destroy, and where thieves break in and steal. But store up for yourselves treasures in heaven, where moth and rust do not destroy, and where thieves do not break in and steal. For where your treasure is, there your heart will be also.
--Matthew 6:19-21
--Matthew 6:19-21
Headin home right now... got to stop for a voltmeter check it adjust it and then reset the ECU. HOPEFULLY after all this we will be good to go...
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
