more hondata BS
TR Registered Member #5
on
94-95 B18C
93 B17A
93-95 B16A Del Sol / Civic
92-95 D16Z
Ok so for the h22a application they dont make a hondata h22a chip so I have to use another damn ECU. I saw where they used a GSR ecu on import review and it lost 50HP from 4200-5300RPMs when plugged into the h22a motor cant be having that shit. So my question is what the hell ecu should I use for the stage 3 I want to get? Im sure it can be tuned up to run better in the aspect of the b18c but which one would be a starting ground to use with the h22a? thanks
I also heard that hondata has preinstalled p28 ECUs but Im not too keen about using a SOHC VTEC ecu for a DOHC VTEC.
93 B17A
92-95 D16Z
http://www.floridaracing.org
Guest
Posts: n/a
1 d0|\|7 7h1|\|k y0u|23 u|\|d3|2574|\|d1|\|g 7h3 c0|\|c3p7 0f H0|\|d474. \^/h47 H0|\|d474 d035 15 m4k3 7h3 3p|20m c0mpl373ly p|20g|24mm4bl3. 7h3 0|\|ly d1ff3|23|\|c3 b37\^/33|\| 7h3 50HC 4|\|d D0HC c0mpu73|25 4|23 7h3 71m1|\|g fu3l m4p5 4|\|d |23v l1m17. 50 17 |234lly d035|\|7 m4773|2 \^/h47 7yp3 0f 3CU y0u 574|27 \^/17h b3c4u53 y0u \^/1ll 3|\|d up 0|\| 70p 317h3|2 \^/4y. |234d m0|23 0|\| \^/\^/\^/.h0|\|d474.c0m
7h3 0|\|ly p|20bl3m \^/17h 4|\| h224 15 7h47 7h3y h4v3 53c0|\|d4|2y 1|\|74k3 |2u|\||\|3|25 \^/h1ch \^/0uld 317h3|2 |\|33d 70 b3 c0|\|7|20ll3d by 7h3 3CU (G5|2 \^/0|2k5 g|2347) 0|2 by u51|\|g 4|\| M5D |2pm 4c71v473d \^/1|\|d0\^/ 5\^/17ch 70 0p3|\| 7h3 |2u|\||\|3|25. 317h3|2 \^/4y 15 f1|\|3 bu7 1d p|23f3|2 7h3 3CU h4|\|dl3 17.
