Intake manifolds
What is the best intake Manifold to run on my B16 I was looking at either the CTR or Skunk manifold. also what is a good trottle body to use with these intake manifolds had my eye on the spoon 70mm.
it's whats on the inside that counts!
70mm will be too big. go with the type R 64mm. thats just about the right sized. about the intake go with the SKUNK2 intake. its a damn good piece of work.
Good luck
Good luck
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
AIM: jasonbadler
813.508.PLAN (7526)
Skunk2 manifold all the way... I know where you can get one for around $300 pm me if you need it.
As far as the throttlebody... if you wanna spend $600 then buy one(Type-R)... if you wanna spend $150 then get one bored out. Mine is bored out to 64mm with a skunk2 intake manifold and it runs great...
Notice: I have a B18 and 64mm is plenty. 70 is WAY overkill especially for a B16.
Joe
Socialized Medicine?
Joe
Originally Posted by President Abraham Lincoln
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Originally Posted by a former president of the US
One of the traditional methods of imposing statism or socialism on a people has been by way of medicine. It's very easy to disguise a medical program as a humanitarian project.
Guest
Posts: n/a
go with whatever is cheaper which would probably be the itr unless you can find a damn good deal on a skunk2 reason being both are great manifolds however the skunk2 and the itr are pretty much exactly the same with one exception. When skunk2 made their manifold for the b18c they pretty much took the itr manifold cut the flange off of it and put on a flange that would bolt to the b18c head. Since you have a b16 motor the itr manifold will bolt right up so save your money and get the itr manifold.
Robster
Robster
Id personally go with a skunk2 and an overbored stock throttle body this is what im running.the spoon TB is a bad bitch but have you checked the $$$$ on them? thats a little too much for my wallet. Just my $0.02
-Adam
-Adam
________________________
go with the skunk2 that is what i have it helpes i noticed a diffrence but some people say its not that big but anything is better than that stock gs-r manifold the throtle body i say spoon sports that is what i plan to have fasthatch is right they will hit you in the wallet!
97 ITR-Mugen Equiped
04 Honda 600RR
04 Honda 600RR
Guest
Posts: n/a
let me ask some of yall a question he has a b16a the itr manifold is a direct bolt on. The skunk 2 is an exact cncd copy of the itr manifold except with a different flange. The skunk2 was made so you could bolt on a good intake manifold onto the b18c and to make things easy skunk just copied the itr manifold so if you are going to get a manifold to go on a b16a why would you spend almost twice as much on the skunk2 than the itr?
Robster
Robster
hey that is a very good point i was under the impresion that he was doin a gsr oops oh well but i still say go with the spoon sports throtle body although i saw a bbk for our cars the other nite an it is 70mm all the way threw it doesnt tapper like the spoon but my vote still goes to spoon
04 Honda 600RR
04 Honda 600RR
