CAR DIED!! need ur advice as to what happened?
Old Nov 11, 2001 | 06:33 AM
kayoken~CIVICex's Avatar
.... well as i was driving on 275 i was cruising in 5th gear at around 3500 rpms.... the traffic slowed down and so did i.... at around 3000 i noticed that my car was hesitating... its hard to explain but i could feel the slight hesitations as if it would die out and then come back on... and i think the car backfired several times while this was happening... i dont really know what backfiring is suppose to sound but i think that was it...
so i put it to 4th gear and the rpms picked up and everything seemed fine... well as i exited the highway i approached a red light so i had to slow down...as soon as the rpms went to 3ks it started doing it this time its worse! then all of a sudden the engine died out...... i tried to start it but it wouldnt start... so i ended up towing it last night... once it got to my house i started it and everything sounded fine... revved it out a couple of times and things seemed normal... so next morning i checked the plugs and one looked really bad... like a part of the tip got melted off... (im talking about the j shaped tip...) so im guessing my car detonated at this particular cylinder? what kind of engine damage do u think my car has? and what are my possible solutions for this? THANKS FOR ANY REPLIES...
Old Nov 11, 2001 | 06:46 AM
Definately sounds like detonation. Is your car stock? Any info on your car will help
Old Nov 11, 2001 | 06:52 AM
im guessing its detonation as well... but in my case if i would pick up the rpms it would run fine but as soon as it hits 3k or below then thats when it would do all that.... is that how detonation is?
its a honda civic ex... with a 55 shot...and msd ignition... the last time i used n20 was last week.... thanks 4 the reply.
Old Nov 11, 2001 | 09:16 AM
GOTTI's Avatar
OEM Parts Specialist
i would talk to a Mr. Self Destruct on that matter before you do anything...he knows his shit and wont tell you wrong...
just my .02
Old Nov 11, 2001 | 10:16 AM
Gotin's Avatar
Sayien
yep detinotaion sux!!! it killed my car. it happened to me cause an hour before i was driving my little cousin messed around with my BTM and was turning the knob. try getting another spark plug and put you timming back to stock. see if the car runns right. my car detonitated for a good year but it drove fine until higher rpms.
-B.J.F-
Old Nov 11, 2001 | 10:21 AM
MY TIming for my car is set at stock... and if i do run the n20 the timing retards ignition by 4 more degrees... cam timing is also stock... help someone...mr selfdestruct? bill?
Old Nov 11, 2001 | 10:27 AM
someone told me that it could be a misfire is he right? would a misfire coz the tip of the plugs to melt off? and if it was detonation is it safe to presume im looking at a rebuild?
Old Nov 11, 2001 | 02:28 PM
sorry for the stupid question but wheres good place to get a compression test done? besides honda...
