Type R trany in a GSR ?s
Guest
Posts: n/a
Iam havin acura rebuild my tranny on monday and i told them that i want them to put type R guts in my tranny and a type R clutch has anyone did this before? reply and tell me how it came out and if u noticed a diffrence or not? and i f it casted a lot?
I would have thought it would be cheaper to just source a tranny from a 99+ Civic Si and install a quaife. If I remember right its the same tranny as the Type-R just without the LSD and a different final drive.
Originally posted by "Someone"
Originally posted by 95civex
someone explain lsd to me please...not smart ass drug related answers though...doesnt that have something to do with all 4 tires moving or something?
Jorge
Originally posted by civicextpa
LSD=Limited Slip Differential.This will allow you to spin the to front tires.
Jorge
Jorge
In an open diff car for instance a FWD civics the torque output to the wheels is limited to the point where one of the wheels begins to lose traction. For instance if you were at the strip and doing a burnout youd notice that one wheel is spinning while the other isnt. This is because the same torque is being applied to both wheels regardless of which has the better traction and since one wheel has already started slipping it doenst take a great amount of torque to keep it spinning (therefore the other wheel is stationary). Now take a car with a limited slip differential (lets say a clutch pack LSD) and take it to the track for some burnouts. Well now youll notice that both wheels are spinning and tossing up smoke. This is because the diff now transfers torque to the wheel that has has the most traction (this little dance goes back and forth between wheels) and the torque applied to the wheel is limited to the point where the clutches in the diff begin to slip. Aside from doing burnouts a LSD is great for cornering since the wheel with better traction is given more power and thereby helps you move around the corner faster and safer. Understand it now?
