Balancing a built engine question
Old Oct 31, 2001 | 06:31 AM
leadfootedfool's Avatar
Eat soot
Balancing an engine mostly involves weighing the piston/rod assembly and making sure that all four assemblys are within a certain tolerrance of each other. The heavier rods and pistons have a very slight amount of material removed from them to equal the lighter ones. To have the crank balanced involves spinning the crank (most of the time with the flywheel clutch installed due to its heavy weight) and removing material from the crank in heavy spots and that would give you a completely balanced engine. So anyway what Im saying is that its a lot easier to get the engine balanced when its not put together yet. Im currently having mine balanced at Dwans in pinellas park. The cost balancing the pistons rods is $100. As for the head porting and polishing it might be a better idea to look for a new performance head with stainless valves even though expensive might be a better overall deal. After spend anywhere from 300 to 500 for a port and polish then new valves cleaning it new seals and seats you could pay more than a new head. Also the more valve jobs done on a head the worse it becomes.
Old Oct 31, 2001 | 09:06 AM
b16a2pwr's Avatar
ALLJDM
no one locally can do a good job of P&P?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Oct 31, 2001 | 01:02 PM
KJ's Avatar
KJ
bored at work
What about Topspeed in Naples. Ive heard some good stuff
about them. Anyone had any experiences? John dynoed
any?
Old Oct 31, 2001 | 01:11 PM
Bill's Avatar
Livin' in Seattle
Bleh Id be wary with Larry. I dont trust that guy as far as I could throw em. If you do end up sending the head there dont expect a quick turn around...itll be more like 8months or so before you get it back.
