SOHC transmissions
Will a transmission from a D16z6 bolt ont to my D16y7 or do I need the newer one from a d16y8. Would I need any parts from the shift linkage or anything else that might be different?
Guest
Posts: n/a
the one from the d16z6 will bolt up just fine nothing else needed except the tranny. You will have much more friendly ratios. The tranny from the d16y8 has all of the same ratios as the d16z6 only difference is 2nd gear from both trannies. On the d16z6 tranny 2nd gear ratio is 1.9 the d16y8 2nd gear ratio is 1.909. A shorter 2nd gear is nice and all but keep in mind your rpms will drop more on the 2-3 shift.
Robster
Robster
