ball joints going bad?
Old Oct 16, 2001 | 08:15 PM
Bill's Avatar
Livin' in Seattle
yes you will hear a noise but only if the ball joint is to the point where it is metal to metal contact and siezeing.
Easy way to check though is to look at the ball joint boot. If its cracked and dry (no lube) then chances are its FUBAR. To check further seperate the ball joint and check for fluidity of movement.
Old Oct 17, 2001 | 07:30 AM
Durdan's Avatar
No Ants Drift Member
easiest way to check it..
1) disconnect negativebattery cable
2) jack up vehicle
3) grab wheel at top and bottom and try to move it. if it moves see where at. there will be very slight play even if its normal. but look at the joints and/or bearings
RIP Tim. i miss you, buddy
Old Oct 17, 2001 | 10:30 AM
KJ's Avatar
KJ
bored at work
How do you get those things out/in? Machine shop press?
Old Oct 18, 2001 | 03:08 AM
Durdan's Avatar
Originally posted by "Someone"
Originally posted by Dusty
i think vertical play in the wheel is hub and horizontal play is tie rod related....
mine had horizontal play. ended up being inner tie rod
verticle play can be hub and/or ball joint and/or upper control arm bushing and/or lower control arm bushing related depending on the severity. horizontal play can be tie rods OR hubs. a bearing is round. if is has play up and down then it has play side to side.
