Skunk2 Cam Gears?
Hey guys... I was just about to order my JUN cam gears and I just found out that they are on backorder and could take up to 2-3months!!! I cant do that. So I thought that my second best choice is the Skunk2 Cam Gears? Any opinions on this matter?
then either order some toda cam gears or some hks cam gears like what denise had on her motors. same quality as the juns and far better than the skunk2s imho.
200 points away from a 300
uhhhh....Toda????? uhhhhh......Spoon???? HKS too.. Any of those would be a better choice than the Skunk2s becuase they all use the factory cam gear with an adjustable plate over it for the best quality. Skunk2s also go up to 10deg. advance where if it slips it could do some serious damage...Todas on the other hand have only 5deg. of advance/retard which is more than enough.
'00 FBP Si
Sebring rule in effect
'00 FBP Si
Guest
Posts: n/a
[qu073][1]0|21g1|\|4lly p0573d by "50m30|\|3"[/1]
[1]0|21g1|\|4lly p0573d by b164|24c3|2 [/1]
uhhhh....70d4????? uhhhhh......5p00|\|???? HK5 700.. 4|\|y 0f 7h053 \^/0uld b3 4 b3773|2 ch01c3 7h4|\| 7h3 5ku|\|k25 b3cu453 7h3y 4ll u53 7h3 f4c70|2y c4m g34|2 \^/17h 4|\| 4dju574bl3 pl473 0v3|2 17 f0|2 7h3 b357 qu4l17y. 5ku|\|k25 4l50 g0 up 70 10d3g. 4dv4|\|c3 \^/h3|23 1f 17 5l1p5 17 c0uld d0 50m3 53|210u5 d4m4g3...70d45 0|\| 7h3 07h3|2 h4|\|d h4v3 0|\|ly 5d3g. 0f 4dv4|\|c3/|2374|2d \^/h1ch 15 m0|23 7h4|\| 3|\|0ugh.[/qu073]
My 5371m3|\|75 3><4c7ly
Guest
Posts: n/a
theyre refering to cam gears not cams. Dont know exactly how many of you have actually inspected the skunk2 cam gears from what I hear there were 2 batches the first wasnt too good and the second witch I have opbserved are very nice top notch quality and construction VERY VERY VERY light and the material isnt a slick material so tightening it down some with locktite you shouldnt have any problems with them slipping.
Robster
Robster
Originally posted by "Someone"
Robster
Robster
A HA!!!!!! I must have read the post wrong!!! OOOPS!!!!
