PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
  1. Easy question/answer
  2. quick question about swaps
  3. 03 Si at Mastro
  4. B Series shift linkage for EG Civic
  5. Okay Read This If U R Reading This
  6. Hamp Oil filters
  7. clutch question!!!!!!!
  8. Injector ?'s vtec/non vtec ---HELP---
  9. obd1 ecu in a 96 civic IACV questions
  10. Final Drive 4.7
  11. EG Foglight Question..
  12. feedback on light flywheel
  13. vtec silonid question????
  14. eisles machine shop
  15. f23 head swap??
  16. Maintenance required light....
  17. Swap!!!
  18. And yet another problem with the GS-R
  19. What header for a B in an EF?
  20. What are you working on
  21. How can i get del sol seats into my crx
  22. idle problems, CEL
  23. h22a problems!!!!! PLEASE HELP!!!
  24. New addition to the family!!!!!
  25. Idling Problem with my GS-R
  26. header paint?????
  27. help????
  28. 97 Civic LX OVERHEATING PROBLEM????
  29. b16 ECU
  30. electrical problem
  31. honda/acura tech i need some help
  32. need help!!!!!!!!
  33. How to make your D1.5 faster in 5 min's!
  34. strut install Q's
  35. Its going down... couple questions
  36. Neptune EMS is back in florida.
  37. Accord suspension questions?
  38. HELP!!! transmition
  39. Whats the best web site to buy jdm engines?
  40. Just A Lil Note!
  41. Header problems....
  42. got a obd0 ls
  43. RC and Precision
  44. a/c promblem
  45. Breakin up in vtec
  46. 95 ex coupe upgraded cam?
  47. Mount question
  48. wanting to moon cut my valve cover
  49. Machining questions
  50. need machine shops
  51. honda wear tank question "need help please"!!!!
  52. overheating question
  53. Tranny Question???
  54. fuel pump question
  55. GSR Head??? Help Me
  56. Fast honda?
  57. water pump
  58. gsr intake mani on an ls head
  59. Clutch Kit Question......
  60. obd1 conversion question
  61. GSR Motor WIth civic Ex harness???
  62. car wont start.. help please
  63. 92 civic
  64. b20 vtec turbo
  65. Turbo help!!
  66. Radiator help
  67. ****itr***question?****
  68. idle problem
  69. P/w and P/L Anyone know how to install them?
  70. over heating?
  71. Are D16Z6 & B16A Drive axles compitable?
  72. Cam Specs. Jdm B16 - B18 Gsr
  73. center cap for rota wheels?
  74. question about turbo and wastegate
  75. i need help i have a ???? please
  76. G35 HID's
  77. My D16a6 Build...
  78. Problem still going on (BIG PROBLEM)
  79. 53000 rpm civic!
  80. B18b1 machining
  81. integra exhaust
  82. turbo question
  83. bov placement
  84. need help with my h22a prelude!!!!!!
  85. Timing for D15B7
  86. difference between cable and hydro trannys
  87. Honda Accord problems.
  88. New eg owner here
  89. head gasket leak
  90. Help ME I AM BOOSTED!!!!
  91. Front Lower H brace strut installed
  92. Need Spring Help
  93. DOHC VTEC flywheel ob ls
  94. Hondata K-Pro
  95. Vcon Buddy Club VTEC controller??? HELP
  96. dizzy need help
  97. my cars still slow!!
  98. Shifter Movement???
  99. A Site For Wirin And All Things
  100. valve train question
  101. H2B conversion kit
  102. A few how to's
  103. Need help
  104. what clutch to buy 4 bseries cable tranny
  105. alarm stopped working
  106. Turbo supply shop (fittings, lines, restrictors, etc)
  107. grinding Q's
  108. Clutch
  109. DIY request: 90 DA cluster in my 89 crx
  110. ne1 have a busted b series vtec head
  111. crank pulley
  112. Help! Identifying body kits
  113. HELP!!! NEED HElp Bad
  114. d16y
  115. cooler fan switch for Teg?
  116. need help with 91 hatch bumper usdm frontend with jbm bumper
  117. the build I did
  118. Good deal????
  119. t3 rebuild kit
  120. better track car
  121. Alternator Question
  122. B18b Bore?
  123. Cheap Engine safety mod.....
  124. idle temp too high for teg?
  125. 91 Accord Wagon
  126. first honda... need some help
  127. this is enough.
  128. machining cost for a Ls crank and rods!
  129. Any good EG websites?
  130. Quick Question...Please Help!
  131. how to check codes on obd1 ecu?
  132. EF bumper compatibility
  133. i would like some input......
  134. Ecu Question
  135. new clutch!!
  136. TPS problem
  137. Need someone to school me on a S2000
  138. Prelude Q.....
  139. how long does race gas last?
  140. Hottanking
  141. spring help
  142. About EG front disc swap..help please..
  143. High Compresiion Question
  144. tranny problem help !!!!!!
  145. 96 integra LS b18b1
  146. Turbo and Nitrous, am i insane???
  147. v-tech selenoid
  148. Q: K series swap....
  149. motor swap need help
  150. 6k or 8k hids
  151. '94 Teg Leaking Antifreeze in Gulfport...
  152. Stolen: Circuit 8 Bronze 15 Inch
  153. need vtec
  154. An interesting problem, see if you can help.
  155. new alarm ,,,,quick question?
  156. need help
  157. Ecu Help!!!!
  158. ????? TopMount ??????
  159. bearing info
  160. i need help fast!!!!
  161. Need to know how to fix my power locks????
  162. Calling all FG2/FA5 owners!
  163. Please help, loss of power steering/poss timing belt break?
  164. Steppin out a limb...
  165. built LS VTEC turbo, will the motor blow???
  166. is turbo-kits.com for real
  167. black eg hatch on 60 last night?
  168. mini me?
  169. need ome opinions on a trade(foglights for type-r lip?)
  170. Does anyone know of junkyards with decent selection of Honda/Acura parts
  171. d16a6 block help!!!
  172. Where can i find motor mounts in stock!!!!!!
  173. Need Help
  174. Tail lights wont turn off
  175. Any specific pounds of force to tighten the head nut?
  176. Our new Stroker 2.7 S2000 (**with money shot) X-Rated
  177. ive searched for this answer...
  178. This weekend
  179. what kind of clutch 2 buy for cable b16
  180. Boosted B20 HELP !!!!(overheating)
  181. Mufller installed..pix inside...
  182. my first honda :)
  183. zc parts help
  184. has anyone ever heard of...
  185. Does Any Body Knows Weres The Tranny Computer On A 92 Accord
  186. car bogs at 4k when hot
  187. prelude problems!
  188. H22 or B18c
  189. honda meets
  190. Whats average temperature under the hood
  191. Need Help! Has anyone had the Fuse for the Condensor Fan keep Blowing? 1998 Civic EX!
  192. LS turbo
  193. Broken Motor Mount = Loss of power?
  194. Post ur pics for Myspace!!!
  195. oem or acl
  196. need some tunning
  197. which o2 sensor 2 buy?
  198. K-series people
  199. what head to use...
  200. we need a meet!
  201. 03 accord maint light button or combo
  202. i have a LS with a idle prob
  203. Error code 43
  204. To: All B16 tranny w/LSD owners
  205. dual cam zc with two probs
  206. About a oem stock eg rear section muffler
  207. want to chip my p28 ecu
  208. Need some advice!
  209. h22/h23
  210. will B16 headers fit on my LS??
  211. What do you think about a Regrind cam?
  212. Slick & Wheels
  213. Might me a dumb ? to ask but..
  214. Small but Big problem?
  215. Vtec Solenoid
  216. Need Something cut and welded
  217. oil pan
  218. jdm cluster in eg, no cel
  219. a few honda questions plz look
  220. B16 started after swap , now nothing.....
  221. New problem,kinda odd,help if you can
  222. how to breakin a new motor?????
  223. Cam Timming...?
  224. Need Cluth Help!
  225. need help with my motor
  226. can you bondo????
  227. h22/h23 frankenstein?
  228. single cam f/s cheap
  229. boiling coolant...question
  230. Vtec problems
  231. wireing digram for '88 crx si cluster
  232. Rod Bearings!!!!!!!
  233. help on 97 civic brakes plz....
  234. just got a honda
  235. VTEC not working
  236. Wiring help...
  237. turbo d16 meet in gainsville???
  238. Tsudo Exhaust
  239. b series vtec and non vtec header question
  240. Rear muffler gasket ??
  241. ugly new honda thing
  242. Rod Bearings?
  243. Grinding Sound In Tranny
  244. Help: Welded O2 sensor
  245. B16 Clutch Question
  246. teg jdm convertion
  247. Please Help Me
  248. HELPP on mounting front lip
  249. B16 swap locally
  250. Need Help Ahlo Installation
