HELP!!! NEED HElp Bad
ok so first the throttle cable (i think thats what its called) seems loose or broke i found the little nut just hangin on the the cable so it gets stuck idle at three! and my car is running super slow second of all now when i turn on my car it sound like its turning on in slow motion like the battery is about to die. And i have my lights kinda pulsing like when you have a system hooked up. ever since i grounded that wire from the head to the body everythings been going crazy. All my sensors are out my spedo stoped working. all within a week!!!!!!!!!!!
HELP
check all of your grounds, you also want to checkout the ground cable that goes from the tranny to the body. my car had similar symptons and i coundt figure out what it was but it resulted that it was a bad ground. you'll be surprised all the things a bad ground could make your car do.
I'm with him^. Sounds like a grounding problem. Check all of your grounds....
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
ok now it just went crazy. my bat was dead but my radio still turned on. i stalled then it wouldent turn on and needed a jump. after the jump no my rpm needle is going crazy up n down and not responding to my foot on the gas
So did you add another ground or not?-Bob
