head gasket leak
Old May 12, 2007 | 05:46 PM
yoshi06's Avatar
Default head gasket leak
so im leaking oil from my head gasket i replaced the o ring for the distributor and the valve cover gasket so that leaves one gasket left i need this done fast and cheap and if the head is warped i have another head any shops interested in helping me it a 91 integra--b18a1
Old May 13, 2007 | 06:22 AM
TSX24L's Avatar
there is also a o-ring type seal inside the distributor that can be replaced taking the distributor apart. This leak is usually at the same place the distribtuor o-ring leaks at and if you open the cap and rotor and see oil residual, that seal is leaking. Alot of people miss this seal and usually suspect the distributor o-ring leaking. Some some helpful info for you and your leaks.
I really wish I could do side jobs I would be all over helping you out and for a cheap price. g/l though.
Old May 13, 2007 | 11:25 AM
KJ's Avatar
KJ
bored at work
Honda head gaskets don't leak oil without first leaking coolant into the oil or combustion chamber. The only exception is if the head was poorly machined during a previous repair/modification.
Try also replacing the vtec solenoid gakset and the cam plug.
Old May 13, 2007 | 05:51 PM
yoshi06's Avatar
thanks i will be checking
Old May 13, 2007 | 05:54 PM
crxter's Avatar
+1 with the vtec solenoid seal, leaks all the time.
