Injector ?'s vtec/non vtec ---HELP---
Old May 22, 2007 | 06:21 AM
HatchBack91's Avatar
Oldschool
Unhappy Injector ?'s vtec/non vtec ---HELP---
I a just converted my hatch to mpfi, should i use vtec or stock 1.5 injectors? my car is d1.5 mpfi
im at a loss here! and need some help
Old May 22, 2007 | 06:28 AM
EclipseTurbo94's Avatar
If There Bigger Then The Stock Minuim Injector U Need To Get A Safc So U Can Tune The Injectors N Retard The Computer So It Can Handle More Fuel Other Wise Ur Car Will Not Run N U Need To Know What (cc The Injectors Are So It Can Be Tuned Properly
Old May 22, 2007 | 06:31 AM
Oldschool
they are stock vtec injectors from a delsol sohc i just need to know i guess... should i get a set of stock d1.5 injectors?
Old May 22, 2007 | 07:16 AM
greddy2die's Avatar
1.6 mpfi and 1.5 mpfi are the same cc injector.
Old May 22, 2007 | 08:31 AM
mtber's Avatar
Correct.
Just make sure they are the same impedance as you may have sourced the injectors from a newer vehicle etc.
