RC and Precision
Precision injectors are really bosch injectors.
I have yet to compare the rc & precision injector design/spray pattern.
I have used both precision & rc injectors without any issues on hundreds of cars.
Precision injectors for the most part use a "ball and seat" nozzle style for their Honda style injectors. Looking at a couple crappy RC Engineering injector pictures online it looks like they use a "disc" nozzle style. Precision injectors are manufactured by Rochester/Lucas. Precision simply flow test, calibrate, clean and package the closest matching injectors to one another. Like Mtber said. You will have no problem with either
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Thanks for the info. Another thing is that my factory injectors are high impedance right? If I go with anything higher than 525cc with precision I would have to get a resistor box. But I see RC has high impedance injectors that are higher cc. And with both companies I would have to get clips regardless right? Thanks again.
Proven Power Dyno Services
A++
Built not Bought
A++Built not Bought
Yes, you will need clips regardless.
Rc makes up to a 750cc saturated injector.
Personally I like using a low impedance injector for anything over 650cc.
Basically the RCs shoot a stream while the Precisions shoot a mist.
It is easier to tune Precision style injectors due to there spray pattern. Also idle quality will be better with a low impedance injector.
A resistor box is easy to install. Please don't just cut and twist the wires. I made mine so that I can unplug it if needed, plug in the dummy plug and install stock injectors.
Vance @ 863-604-2139 for any questions
