crank pulley
Old May 10, 2007 | 09:48 AM
custom240sx's Avatar
DC Crew Member #1
Default crank pulley
Has anyone ever taken a stock crank pulley or even a light weight aftermarket one and had it shaved down to where only the alternator belt was used? I was thinking about doing that to my b18a1 to free up some horsepower but I was actually wanting to do it with the stock pulley so I can keep the harmonic balancer. One question would be, does it make the pulley weaker by cutting it down? Basically, I am not using the powersteering or ac so on the pulley it is just dead weight.
Old May 10, 2007 | 09:57 AM
Old Renegade's Avatar
Cool Runnings
uh i really think you would throw it out of balance. as for the harmonic balancer it is to reduce bearing damaging vibrations.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old May 10, 2007 | 10:31 AM
nocomply540's Avatar
is retired...
How about an aftermarket crank pulley designed for only an alt. I take it the aftermarket pulleys don't come with the harmonic balancer??
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old May 10, 2007 | 10:37 AM
KJ's Avatar
KJ
bored at work
I've used the stock pulley machined down. I only had the p/s portion removed. I'd recommend getting it balanced if you did that though. I ran mine for over two years with no problems.
I originally had mine shaved because the p/s portion was chipped. I wouldn't expect to see any real gains by doing this though but it is alot safer than running an aftermarket pulley.
Old May 10, 2007 | 11:22 AM
itsslow's Avatar
I-VTEC, do you?
^ exactly get it professionally lightened and shaved.. and make sure you get it balanced after shaving it down.
Old May 10, 2007 | 01:32 PM
DC Crew Member #1
Well I was deff. wanting to do it to the factory pulley but I was just wondering if anyone has done this mod it any pulleys. I had the ps shaved too but I figured I wasn't using the ac either so why not shave that. I mean its just power being wasted by the motor. Also, why would you need it balanced if you use the stock pulley that has the harmonic balancer in it already? I mean if it is shaved smooth completely across the pulley then how would you be throwing it out of balance?
Old May 10, 2007 | 01:48 PM
Sypher's Avatar
just buy a oem ctr pulley, only uses the alt. belt
Old May 10, 2007 | 01:53 PM
DC Crew Member #1
I was thinking ITR pulley...I want to try and stick with a harmonic balancer.
Old May 10, 2007 | 02:32 PM
Cool Runnings
hell no do not do that.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old May 10, 2007 | 02:33 PM
Sypher's Avatar
yup i have no idea what im talkin about, your right
