VTEC not working
Old Apr 26, 2007 | 04:24 PM
doefat07's Avatar
Default VTEC not working
sorry i searched but nothing. I have a mini me swap y8 head. vtec is not kicking in. im kinda new to hondas but i heard they have to be grounded. is that the ground wire from the engine to the front radiator support? because mine is not attached and the oil level is good.
Old Apr 26, 2007 | 04:28 PM
scott hutch's Avatar
needs vtak fluid!!!!!!!
Old Apr 26, 2007 | 05:19 PM
CEMAYHALL's Avatar
www.CEMayhall.com
Yes I would ground the wire (but that doesnt have anything to do w/ the vtec)
Give a little more detail about the swap ie:
1. Did you do the swap?
2. What ECU is in the car?
Does the Speedo work? (for the retards who are curious as to why I asked this; B/C if the speed sensor is broken, the Speedo nor vtec wont work!)
3. Has it ever worked in the past?
4. Who wired it?
Old Apr 27, 2007 | 12:46 AM
vonrobins's Avatar
love hondas ftw
yes it has to be grounded and make sure that your vss is plugged in , and did you wire the vtec correctly - which im betting not
._________________________
Old Apr 27, 2007 | 12:48 AM
vonrobins's Avatar
love hondas ftw
what make and model is the car and when you did the mini swap did you take the oil plug from the top of the block because if not you have no vtec
Old Apr 28, 2007 | 05:45 AM
doefat07's Avatar
i did not do the swap some idiot did it. i have a gsr CPU and yes the vtec did work before even with the swap. the speedo works and is a si speedo and was usually hitting at around 5.5 rpms. now it just keeps going no kick. its a y8 head with a 94 bolck i cant remember the model. its in a 98 dx civic.
Old Apr 28, 2007 | 05:47 AM
doefat07's Avatar
first off thanks for the help but what is a vss where can i find it
Old Apr 28, 2007 | 05:48 AM
doefat07's Avatar
'where can i find the oil plugs ...thanxfor ur help guys
Old Apr 28, 2007 | 08:19 AM
vonrobins's Avatar
love hondas ftw
vss-vehicle speed sensor -its a cable that goes from the gauge cluster to the back of the transmission
Old Apr 28, 2007 | 01:17 PM
doefat07's Avatar
hmmm i look arount for any loose cables.
