quick question about swaps
i've seen them before. i'm looking for a website that states what you can swap into any honda and what all is needed.
e.i 98 civic you can swap in a b16 and you need this this and this.
but it has a huge chart for every honda
hasport has some good info and sells the shit you need.....most swaps will all need roughly the same stuff
b series = mounts, linkage, ecu, and possibly a jumper harness
d series = possibly and jumper harness and ecu but generaly swap right in
run a chipped p28 from pherable.net (obd1 like your car) and he also sells the wiring you need and make sure that your intake manifold and dizzy are obd1 as well...if there not its not hard to find them.....or you can convert your intake manifold to save money (injectors/throttle body).....thats how i would do it at least
