Boosted B20 HELP !!!!(overheating)
Here the deal i have a B20 Jaskon Racing S/Cd and i am haveing overheating problems....i replaced the thermo....but i am runnin the stock Rad from my D-series back in the day......i just picked up the B20 from hmotors and put it in the car (no i didnt do the Waterpump or Timing Belt STUPID i know) i needed to get the car together.....bascially i need some help with what is the deal.....someone help me out and let me no what the deal is or if neone has run into this problem i jsut dont want to throw allllllllll these parts at it and get no where for ex. performance rad, water pump, etc. i need some help form yall i thought that replaceing the Thermo would do the trick b/c it was bad but that isnt it b/c its still boiling Someone HELP me please most of yall no who i am from the meet this year......and if neone has ne lead on a Performance Rad, or nething like that the would be of great help PM me or post ill be checkin......peace yall
Matty P
Matty P
I <3 4DR
I <3 4DR
ground wires?
i love AUTOZONE
i love AUTOZONE
bleed the cooling system ? Any fluid coming from the weephole on the water pump itself ?
Hondata saves lives
Hondata saves lives
Bleed the system first. Take the radiator cap off. Start the car. Jack the front-end of the car up. Let it run for twenty minutes like that. Top off coolant/water as needed. Lower the car to ground level. Let it run for five minutes like that. Top off coolant/water as needed. Try that and post back
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
I have tried all the bleeding coolant trick and i have gotten nuthin. What is the thing w/ the ground wires about why would that make it over heat ?? do u guys think the rad is bad or something like that or could the radiator cap not be holding pressure b/c the Temp gauge says its fine when it runs its just bubblin inside the reserve bottle i just dont get it
I <3 4DR
I <3 4DR
Not a bleeding trick. That's the proper way to bleed a cooling system
If the overflow is bubbling go ahead and replace the water pump
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
fan coming on?
http://www.houston-imports.com/forums
http://www.groundlevelimports.com
Stock 10sec crx
Stock 10sec crx
