Q: K series swap....
Old May 7, 2007 | 04:28 AM
fokissed's Avatar
Default Q: K series swap....
1: How much boost can the stock K20a2 handle?
2: If I have a K24 bottom end and a K20a2 head Which wiring harniess do I use or does the K20a2 harniess work with the k24 bottom?
Old May 7, 2007 | 04:57 AM
NSXtacy's Avatar
Go Fast Crack Pipe
1) We are tuning an a2 today that is set for 20psi of boost on stock sleeves. If fuel is there we could see in excess of 425whp. Others have made over 500whp with stock sleeves, but as usual, the longevity is decreased.
2) bottom end does not matter which harness, just need to use the crank position sensor off the K20.
"It's OK to Smoke V-8's" - Surgeon General
www.2NRWerks.com - NSX, S2000 & RSX specialist. AEM, Hondata Kpro & Crome tuning provider. Custom built F, K & B series motors. Custom "Safe" Nitrous Kits and NOS Refills (While-U-Wait). Suspension/Brake Specialists & Alignments for lowered cars. On the quest for 700whp S2000 roaming the streets early Spring.
To Schedule An Appointment Call: (813) 876-VTEC
<< Reputations are so overrated! Don't hate on me 'cause I build fast cars.
Old May 7, 2007 | 09:30 AM
civicized's Avatar
A lot depends on which k24 bottom you have. Accord and crv rods are not as strong as tsx. TSX bottoms have been handing 400 hp plus a bit more.
Old May 7, 2007 | 03:55 PM
fokissed's Avatar
i was looking to redo the whole bottom with a stroker kit. just need to know if i have to redo the top end with after market parts to handle high boost.
Old May 8, 2007 | 11:36 AM
NSXtacy's Avatar
Go Fast Crack Pipe
Why leave the top end stock if you put so much time and $$$ in the bottom end. You don't have to go crazy on the top end 'cause you are forcing air into the motor unlike the N/A application that needs to drawl air into the cylinders.
Old May 8, 2007 | 12:05 PM
Sypher's Avatar
made 650 of a k20/k24 setup
Old May 8, 2007 | 01:28 PM
BigBodySmith's Avatar
Retired Street Racer
Wow, more info please!!!!
My Old Honda
Old May 8, 2007 | 02:13 PM
Sypher's Avatar
k24 shortblock with k20 head all stock no internals
custom turbo kit tuned by Jason aka Stoopid
ill look for a vid real quick
Old May 8, 2007 | 04:56 PM
na200whp's Avatar
Powered by BOOST
your refering to Onix's car right?
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old May 8, 2007 | 06:12 PM
Sypher's Avatar
yesir
