Q: K series swap....
Old May 8, 2007 | 06:15 PM
Janky99's Avatar
Honda Guru
Originally Posted by NSXtacy
2) bottom end does not matter which harness, just need to use the crank position sensor off the K20.
Why have I never heard of having to use the k20 crank sensor, I have a k24 bottom end and k20 head... no CEL's.. hmm.. do you know why this is required? -Ben
Old May 8, 2007 | 07:12 PM
fokissed's Avatar
Im looking to do the top end too. top end is easier to take out of the car later on when i go to do the internals.
also whats the highest compression pistons i can go with sleeved walls and 20 psi boost?
Old May 9, 2007 | 02:48 PM
Janky99's Avatar
Honda Guru
Sleeved? Whatever you're turbo is good for. if you get some good pistons/rods and a sleeved block it would have the potential to put down more power than your car could handle.
Old May 11, 2007 | 01:19 PM
60-1EK's Avatar
Engineer at the source
Originally Posted by Sypher
yesir
Didn't that car blow up? He is building a new setup last time I talked to Jason and Onix was hanging with him.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old May 11, 2007 | 02:45 PM
Sypher's Avatar
it blew when the boost was turned up to hit the 700 mark. when it was at 650 it ran perfect with multiple passes and on the street
Old May 11, 2007 | 07:44 PM
fokissed's Avatar
which k24 bottom are u using? and what type of externals do u have?
like:
manifold
water pump
fuel rail
fuel pump
Lines
stuff like that all stock or after market?
