Quick Question...Please Help!
Old May 8, 2007 | 01:54 PM
XxSlick813xX's Avatar
Default Quick Question...Please Help!
I drop a JDM 1.5 Single Cam V-Tec into a 1990 Honda Civic Hatch DX... I paid a guy to switch everything over to a obd1 and he took out the resister box... He said "that I dont need it". Well, my car now doesnt start because of no fuel gettin into the motor. The fuel pump is not workin neither are the injecters. I bypass the fuel pump so I know my fuel pump isnt bad. What I need to know is, am I suppose to have the resister box in or is it sumthing else? Thanx
Old May 8, 2007 | 01:56 PM
CRXkid24's Avatar
uh oh
try main relay
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old May 8, 2007 | 02:11 PM
Sypher's Avatar
if he kept the obd0 injecters in the intake then yes you need that resister box in there.
otherwise if he put obd1 injecters in you need to cut and solder all 5 wires from the old resister box plug. 4 of thoses wires are your injecter 12+ power to each injecter. the other wire is the 12+ from the ign
without that the injecters wont fire
Make sure you have obd1s before you splice that plug together!
Old May 8, 2007 | 02:13 PM
I have obd2 injecters
Old May 8, 2007 | 02:15 PM
Sypher's Avatar
same thing applies then
cut and solder all 5 of those wires from that old resister box plug (small green 6 pin plug)
He also swapped your injecter plugs to obd2?
none of that was needed, the obd0 ones are the same thing and would have saved time
So, your telling me to connect the five wires that were going to my resister box together. All together?
Old May 8, 2007 | 02:16 PM
Yea, the plugz are obd2
Old May 8, 2007 | 02:17 PM
Sypher's Avatar
if your injecters are for sure obd1 or obd2 yes. that bypasses the resister box and sends power to each injecter
Old May 8, 2007 | 02:18 PM
ooo, Im not sure if he did that or not, but if he did... why else wouldnt it start?
Old May 8, 2007 | 02:20 PM
Sypher's Avatar
other then that check all grounds, ecu and main relay
