- Water coming out of throttle body
- My Car is in LIMP MODE!!!!!!!! HELP!!!!!!
- My eg hatch dont turn on!!!!help
- Help with mini me swap!!!! PLEASEE!!!!
- brand namd intake or ebay no name intake
- i need help.. i lost my rim key
- HELP!!! mini me swap spraying water out exaust port.. wtf help
- Cluster Lighting upgrade? 98ek
- 99 Civic Ex, need help, AC & body issues..
- em2 help!!!!!!!!!!!!!!!
- how to conect vtec selenoid
- GSR rebuild, lots of smoke, smells like fuel
- Bad LSV oil leak
- Resurface rims?
- Car sounds deeper than usual???
- Help help help plzzzzzzzzzzzzzz
- Ac help! Need working!! Summer is almost here!
- Button behind clutch?
- DC wipers HELP
- Any security/ alarm tips?
- HELP!!!Parts Identification QUESTION!!!! Could you tell me what is...
- Already Swapped bt NEED WIRED!!!!!!
- 1998 Civic high idle, need help!
- B16 hydro tranny problem
- Cluster question 98 hatch
- Black smoke/black dots on my bumper
- wtk: b2 block with jdm head
- In need of help when it comes to my suspension upgrade ...Honda ppl
- a/c Air conditioner compressor cycling fast?
- gsr iacv
- weirddd check engine light, can anyone figure this out?!?
- new to me oil leak...
- idle problem plz help
- Bumpers
- Civic running like crap. Need input.
- Water Pump Weep Hole
- Tranny Mech LSD, LS 5th?
- honda fit lowering spring help
- need someone to wire tuck my hatch
- Man this civic gives me so many problems!!
- need sombody to help me put in my throwout bearing ill pay you
- teggy issues help!!!
- ****heelp!!!!!..car wont go past 4200 rpm***
- Ecu Question Q31 fried and i can't get the ecu to go past 3500 rpms
- Gsr head LSV and ECU Question
- build questions!!!!!
- 98 integra ls turbo tuned on crome to much fuel pressure help
- My H2B w/ Pro2s Dyno Tuned 249hp 182 TQ
- Gsr cam rail bolts/ studs
- Engine code problem
- need help with high idle on my civic
- I need help integra clutch pedal wont hold pressure
- Looking For a shop in or near Ocala to replace my clutch on my 07 si
- stripped engine to tranny holes fix HELP
- need some work done need cam gears installed on my ls
- Help with SI Cluster
- 1996 Accord Headlights Advice
- honda smoking?
- 89 civic lx starts but warms up and throws codes!!! NEED HELP ASAP!!!!
- motor Swap
- tranny problems 94 accord Ex F22b1
- Honda Brake Pads vs EBC Redstuff
- Speaker wiring question
- resistor box installation
- Cooling fan problem...please help!
- EG AC problems
- Cable Clutch wont engage???
- can someone walk me through installing some new brake lines??
- P75 ECU question
- EG gauge problems..Not sure where this sensor goes
