EF hub problem?
Old May 26, 2010 | 06:40 PM
19_ef8_91's Avatar
Project LS ED6
Default EF hub problem?
ok, now, you see where the placement of the hub is? its a lilttle too far back, i was told that if i torqued down that nut in the front of the crossmember, it would pull it forward. the bushing was bad so i went to Honda and bought new ones. Replaced the old one and torqued it down to spec, and........ still in the same place. can anyone help me figure out what to do to rectify the problem? i am willing to pay a lil bit-o-cash(current rate per hour for labor) to someone that can fix this.
727 642 4400
anyone?
Keepin it Old School
"Old Skool EF" Member #181
Old May 26, 2010 | 06:48 PM
flatrex's Avatar
crx hatch sedan
Traction bar will take care of it for you.
Old May 26, 2010 | 07:22 PM
FrodoGT's Avatar
Found the Vtec switch.
Its also possible that your radius arm was damaged and replaced with one that was a bit longer... I had that on a crx I had and it drove me nuts until I figured out that nothing was bent or broken..but it was still all screwed up.
TR Old Skool EF Crew #24
Old May 26, 2010 | 09:14 PM
custom240sx's Avatar
DC Crew Member #1
Maybe they used a DA radius bar instead of EF.
Old May 26, 2010 | 10:50 PM
FrodoGT's Avatar
Or a sedan.. anyone know if the hatch has a longer arm than a crx? I dont think it does.
Old May 27, 2010 | 04:21 AM
19_ef8_91's Avatar
Project LS ED6
i didnt even think of that, but if anyone lives near or in port richey thats willing to at least look at it, i'd appreciate it.
Old May 28, 2010 | 02:05 PM
19_ef8_91's Avatar
Project LS ED6
is it possible that some moron used a different axle than one for an ef? it seems that if i straighten out the axle, the wheel would stick out about 2 or more inches.
Old May 28, 2010 | 05:49 PM
88_Hatchy's Avatar
I'm cooler than you
How about tomorrow you go to the junkyard and spend $5 on another radius bar.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old May 28, 2010 | 06:15 PM
19_ef8_91's Avatar
Project LS ED6
its not the radius bar... the drive axle looks too long. and the radius bar is stock and unmoved from the crossmember. THE AXLE LOOKS TOO LONG>
Old May 28, 2010 | 07:14 PM
88_Hatchy's Avatar
I'm cooler than you
I don't care what it "looks like". The axle won't push the wheel back like that.
