EF hub problem?
Old May 28, 2010 | 08:20 PM
19_ef8_91's Avatar
Project LS ED6
Originally Posted by 88_Hatchy
I don't care what it "looks like". The axle won't push the wheel back like that.
ill give u 50$ if u can prove thats the problem AND fix it maybe $75 since ur in tampa
Keepin it Old School
"Old Skool EF" Member #181
Old May 29, 2010 | 07:28 AM
19_ef8_91's Avatar
Project LS ED6
Originally Posted by 19_ef8_91
ok, now, you see where the placement of the hub is? its a lilttle too far back, i was told that if i torqued down that nut in the front of the crossmember, it would pull it forward. the bushing was bad so i went to Honda and bought new ones. Replaced the old one and torqued it down to spec, and........ still in the same place. can anyone help me figure out what to do to rectify the problem? i am willing to pay a lil bit-o-cash(current rate per hour for labor) to someone that can fix this.
727 642 4400
ANYONE?
Old May 29, 2010 | 10:58 AM
flatrex's Avatar
crx hatch sedan
The axle length cannot effect the caster. Think about it, The radius rod is a solid bar the axles move at both ends therefore the axle will change its angles and the rod will not.
Old May 29, 2010 | 05:22 PM
19_ef8_91's Avatar
Project LS ED6
then the same applies to you my friend. if ucan fix it you got $75
Old May 29, 2010 | 06:34 PM
88_Hatchy's Avatar
I'm cooler than you
I sent you a shared_pm earlier. LMK.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old May 29, 2010 | 10:14 PM
FrodoGT's Avatar
Found the Vtec switch.
If the axle were too long, you would NEVER get that knuckle attached to all 3 points (LCA, UCA and radius arm. It triangulates the position for a reason, so that it is in the same place for a given suspension position every time..otherwise an alignment would be pointless. That axle can slide in and out up to 2 inches or so on the inner joint to allow for suspension compression and steering angles. If that wheel is sitting back like that it has to do with one of the three mounting points, either your crossmember is bent/broken or the uca is in the same condition OR the most obvious and noticeable one is the radius arm is too long/the crossmember/front end is bent/broken and pushed back.
Jack the car up and unbolt the two bolts (for the radius arm) on the lower control arm, then move the wheel into the normal position in the wheel well and see how much longer that radius arm is.
TR Old Skool EF Crew #24
