need new tranny wanna upgrade
i just got a del sol si 93' and my 5th gear sometimes works and some times dont any one got a good tranny i can buy? And if so i wanna know what trannys i can put on the sin gle over head cam to give it a lil more pep i dont know if the bseries tranny will work shared_pm me back thanks
If your del sol is an si model, then you already have the best geared stock d-series transmission.
A b-series trans will not work with a d-series engine.
the symptoms you describe concerning fifth gear are common woth low transmission fluid level...
have you check the trans fluid level??
Liar, you couldn't cut me deeper with a knife if you tried
