h22 turbo eg low oil pressure please help
Old Apr 21, 2010 | 04:04 AM
HaViKTypeR's Avatar
On The Paper Chase
Default h22 turbo eg low oil pressure please help
When she starts up in the morning oil is like 100 as I drive and car gets warmer, oil pressure drops to 0 has rough idle. when I press the gas it shoots up again. What can be the problem?
"Proven Power. Nuff Said"
"God is Good"
Old Apr 21, 2010 | 07:17 AM
HaViKTypeR's Avatar
On The Paper Chase
38 views and no answers............ok
"God is Good"
Old Apr 21, 2010 | 10:23 AM
BlackZ28's Avatar
ppssshsshhhhhhh
does the oil light in the dash come on when it drops to 0?
what kind of balancer do u have?
i wouldnt run the car with no oil pressure
your problem sounds just like something that happened to me a few months ago. turns out my oil pump went bad due to a cheap aftermarket balancer. had Collin over at racingintegration drop the pan and my oil pump drive was in pieces. thankfully i turned off the car immediately when my pressure dropped to 0 and never started it again. had it towed to his shop. he noticed that i had a cheap aftermarket balancer on it and replaced it with a stock piece and a new oem oil pump. he also checked the bottom end and everything was ok. he said i got lucky. been running fine ever since
www.mcgtile.com - Professional Marble and Tile Installation
Racing Integration
Proven Power
Old Apr 21, 2010 | 08:40 PM
91 2DOOR's Avatar
i would say the same thing that and change the oil pump buy a brand new one from honda and make sure you prime the pump first before you put it in the car
if you need any help you can givce me a call i work at a shop 5th gear performance 727-849-2886 bryan
Old Apr 22, 2010 | 05:31 AM
DarksideZ's Avatar
TR Balla Donor Supreme
I'm assuming you are using a mechanical oil pressure gauge, if that indeed is the case my bet is on the oil pump.
Old Apr 22, 2010 | 11:13 AM
HaViKTypeR's Avatar
On The Paper Chase
I tested the pressure using an external pressure gauge and when the mechanical one drops to 0 the external reads 15-20 PSI so Im assuming my gauge is the problem and not the pump.
"God is Good"
Old Apr 22, 2010 | 12:19 PM
NeKe1point0's Avatar
If i remember correctly those guages (ebay) were junk Bobby went with.
Id def check/use a guage that you KNOW is good.
Your oil pump was brand new from Honda when originally installed so it should still be flawless !
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Apr 23, 2010 | 10:45 AM
HaViKTypeR's Avatar
On The Paper Chase
^Lmfao I know both are trash Im getting Autometer replacements
"God is Good"
