NSX calipers on DA Integra
Old May 1, 2010 | 04:07 PM
Alltracfreak's Avatar
Default NSX calipers on DA Integra
ok in the april issue of honda tuning they had a 94 Del sol with 99 NSX oem calipers on it. i was wondering if it could be done to my 90 DA Integra and if so what would it take to do this?????? cuz im cheap and dont have money for a big brake upgrade lol
Old May 1, 2010 | 04:19 PM
Santos's Avatar
nsx calipers and all the misc. shit to make it work wont be that cheap either. just get some brembo blanks with really good pads (ebc..etc) some braided lines, clean fluids and good tires...how much power are you making that you need a big brake kit?
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old May 1, 2010 | 04:55 PM
not about the power just want bigger brakes
Old May 1, 2010 | 05:20 PM
flatrex's Avatar
crx hatch sedan
My friend put nsx brakes on his Crx you can use legend brakes too I believe they are almost the same minus the nsx logo on the caliper I forget the name but there's a company that sells the caliper brackets and rotors so you can use the nsx stuff
Old May 1, 2010 | 05:52 PM
hell yeah no doubt if you could get the info that would be awsome
Old May 1, 2010 | 06:57 PM
marktopia's Avatar
TR Balla Donor Supreme
i have accord calipers on my eg. theres a little biger then da,eg,si ect. check it aout bro. cheap to.
Old May 2, 2010 | 06:38 AM
flatrex's Avatar
crx hatch sedan
Here you go man you might have to call them and let them know what you plan on doing but this is Tue place he got his stuff from.
Fastbrakes.com
Old May 2, 2010 | 07:43 AM
yakosato's Avatar
fourth gen Prelude VTEC uses 11.1" size rotors w/ bigger calipers.1995 Legend LS-C (coupe)-front calipers dual pistons and are similar to the nsx except vents that the nsx has. NSX is too expensive, Legend calipers may need custom brackets to fit?
96-04 RL calipers are 4 piston calipers, consider same pattern rotors or you are going to need custom work.
Also bigger calipers means no donut spare tires. You may need some crazy offset to make it fit.
Old May 8, 2010 | 08:59 PM
A show car gets points for a custom brake swap, otherwise.....
Upgrading to a better pad material will get quicker stops.
Upgrading to wider tires will get quicker stops.
Both will cost less than the NSX calipers.
Yako is right....bigger dia. rotors mean no going to smaller rims
if you get a flat.-Bob
Old May 8, 2010 | 09:16 PM
1lowSi's Avatar
1LowSi is a white guy
just changing the calipers and pads wont make a huge diff it is mainly in the balancing, and bore sizing in master cly
the race car i work on (scca club racer) lotus Super 7 uses 1 piston calipers,& 9" rotors but the setup will out brake 99% of any thing on the track
it has alot of time and setup in the valving for master cly bore
VOUCHES on TR: eda6, 1LowEG02, SUPERCHARGEDCIVIC, Seasicksean, HonkeyDong, Supercrx88, lzylst
VOUCHES on H-T(jdmh22eg2) :neophyte210, RhdRicheeee, russlavoilette,lzylst
Orlandoforums (ThatWhiteGuy) -- Anyone
I LIVE IN DAYTONA BEACH
