Engine feels like its missing, chugs under load...
Old May 15, 2010 | 06:30 PM
Brandon H.'s Avatar
Default Engine feels like its missing, chugs under load...
Friday I had gone in the engine bay with a engine cleaner, large brush, and a hose to clean up the engine bay. I cleaned pretty much everything.
I get back in the car, and it took a little long then usual to start up, then once it did start it ran like shit, would hardly idle. I popped the hood and noticed that I acidently unplugged a spark plug wire. I hook it back up and it idled better. Thought I fixxed it.... I was wrong.
So now, after not driving the car for over 24 hours, I drive home and I noticed that when the car is under somewhat heavy load (like doing 30mph in 4th gear, and flooring it) the motor chugs, almost like the car is bucking...
It does this in any gear under load, or around full throttle. BUT if I keep the rpm's up and the car moving fast, it drives fine.
It never didi this before. What is it? I need it fixxed asap.
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old May 15, 2010 | 07:07 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
Cel?
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old May 15, 2010 | 07:28 PM
custom240sx's Avatar
DC Crew Member #1
Nope I bet I know what it is
Pull your dizzy cap off and dry it out...plus where your spark plugs are and the wires.
Old May 15, 2010 | 07:34 PM
flatrex's Avatar
crx hatch sedan
Water in your cap, gotta keep it dry.
Old May 15, 2010 | 08:18 PM
rangcrx's Avatar
engine building &best
guess if kids did not clean there engines with a hose i would not have so much money!!hope you get it fixed
i love AUTOZONE
Old May 16, 2010 | 02:59 AM
BoostedRacerDad's Avatar
Pops
^LOL... Hows the monster motor coming along? Pm when you get a chance.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old May 16, 2010 | 06:27 AM
Brandon H.'s Avatar
Years of offroad experiance told me water in the cap, I didn't have the time to pull it off, but I figured 24 hours would be enough time to clear it out, expecialy after getting the car to full temp 3 times.
I had also checked if there was water sitting by the plugs and there weas none, and the conections were dry too.
No CEL.
1999 Honda Civic Si
TR em1 crew #43
Old May 16, 2010 | 08:52 AM
Brandon H.'s Avatar
SOOO
I pulled the cap, no signs of water being in it, all the points looked decent but I cleaned them real quick with 800 grit sangpaper, and the rotor on the dizzy looked decent as well. There was just a tad bit of surface rust that came off with the wipe of a rag.
All the wire connections are good, and there is no water in any of the plug holes.
I tooked her out again, and once to full temp, under load its still there. Maybe not as bad but its still there. I slowed down to 40 in fith gear and floored it, and every now and then it had a couple chugs. Feels like it looses all power for a split second. Untill I get over a decent RPM and there isn't much load on the motor, then it clears.
What could it be?
1999 Honda Civic Si
TR em1 crew #43
Old May 16, 2010 | 09:40 AM
DC Crew Member #1
Water in injector plugs? You got something wet that doesn't want to be wet lol.
Old May 16, 2010 | 10:00 AM
Brandon H.'s Avatar
Thing is, its been almost 48 hours, and the motor has been up to full temp atealst 5 times now.... dont ya think it will have evaporated by now??
1999 Honda Civic Si
TR em1 crew #43
