Engine feels like its missing, chugs under load...
Old May 16, 2010 | 10:17 AM
custom240sx's Avatar
DC Crew Member #1
Not really, some of those plastic surfaces don't really get hot plus they have o-rings on them that could keep the water from evaporating. You have to remember, the hose is a "high pressure" water source and can force the water past those seals...but evaporation doesn't have really any pressure behind it...pull off as many of your connections as possible and compress air them out.
Old May 16, 2010 | 10:28 AM
Brandon H.'s Avatar
I will try that. My compressor is down at the moment, but I have a couple cans of duster gas for computers I can blow all the connections out with.
One thing to note, there was no fitting on the end of the hose, it was just water coming out at no pressure.
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old May 16, 2010 | 11:07 AM
DC Crew Member #1
Well in any case, you got something wet that seems to be shorting out in conjunction with timing/fuel. What you described sounded like water in the dizzy cap almost dead on so I am pretty surprised to hear it was dry.
