what do i need to go from auto to manual?
Old May 7, 2010 | 06:51 AM
efkidd525's Avatar
I do what I do
Default what do i need to go from auto to manual?
i am gettign a new cat its auto i wanna change it to manual.
i need a trannyy.
i need shirt linkage.
i need ECU
anything else?
can someone help
17275511898
Justin
TR "Old Skool EF" Member #179
Old May 7, 2010 | 09:52 AM
FoxHondaRider's Avatar
Registered Hater
clutch and flywheel also if its not with the tranny if I'm not mistaken. Usually you have to wire up the reverse lights. I should post pictures of my auto to manual lol I swapped over the whole manual interior harness and cut out the center of my manual car that I wrecked and bolted it to the center of the manual lmao
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old May 8, 2010 | 07:03 PM
Generally I would go to the junkyard and get all the parts that a manual tranny car has that your auto tranny car does not have. Take a good look at your car first. Maybe photo the car so you have some kind of reminder.
If you can find that info, it will be a help to EFKidd as well as others.-Bob
Old May 23, 2010 | 11:01 AM
xxdanib21xx's Avatar
-d15 or d16 Cable Tranny (obvious) change the throw-out bearing while its out
-Shift linkage
-Clutch Cable ( might have to drill a whole in firewall)
-if its a Dual Point u need a Manual PM5 ECU ..PM6 for Multi Point
-Rear Complete Mount 'bracket and mount' M/T
-Left Complete Mount ''^^^^^^^^^^^^^^
-Flywheel w/ M/T bolts
-Clutch w/ Pressure Plate and Pressure Plate Bolts
-Pedal Assembly (Dual Point gas pedal hooks up differently than Multi Point to throttle cable- easy to swap old gas pedal to new pedal assembly)
-Wiring is very easy!! BASIC!!
-I resused A/T Starter and Axles.. im not sure about how axles work with the wagovan though!!
AND PATIENCE!! lol
My conversion ran me about $250 for all parts!... If you need any pointers shared_pm me!! Good Luck!!
Red EJ2 w/D15B vtec (95 Coupe)- DD/Project
Silver GD3 (08 Fit Sport)- SOLD
Red EJ8 (97 ex Coupe)- SOLD
Blue ED6 (89 dx Hatch)- SOLD
SOHCVTEC
Old May 23, 2010 | 11:38 AM
zhillz's Avatar
Porno Music Producer
What is the car? I did it to a 98ex coupe and you have to get a new intake manifold or tb i cant remember which because the iacv is built in on one and not the other.
Old May 23, 2010 | 12:50 PM
88_Hatchy's Avatar
I'm cooler than you
-Shift linkage
This list seems complete. Don't forget some Honda MTF.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
