Need HELP
Old May 13, 2010 | 08:03 AM
CrXSibeast's Avatar
Default Need HELP
ok so my car is going nuts im having for some reason electric problems when the car is on and im starting to drive away the rpm's go nuts like up and down, then at the sametime my engine light turns on and off and my car wants to turn off 2, the only code that is coming up is 13 which is BARO Sensor so right now i have no clue of what to do. anyone have ideas let me know pls thanks
TR "Old Skool DA" Member #39 Crew
Old May 13, 2010 | 08:53 AM
1lowSi's Avatar
1LowSi is a white guy
check ur grounds ALL of them
all so what chassis if crx/ef i had same prob it is the integrated control unit (located on back of underdash fuse box they are know to jsut burn out it plugs in back of fuse pannel
VOUCHES on TR: eda6, 1LowEG02, SUPERCHARGEDCIVIC, Seasicksean, HonkeyDong, Supercrx88, lzylst
VOUCHES on H-T(jdmh22eg2) :neophyte210, RhdRicheeee, russlavoilette,lzylst
Orlandoforums (ThatWhiteGuy) -- Anyone
I LIVE IN DAYTONA BEACH
Old May 13, 2010 | 09:45 AM
iloveboosted's Avatar
TUNER
i can fix that text 8133825779
JAY TUNING! YOUR tuning solutions
ECU Chipping and Reflash, Dyno Tuning,
CUSTOM MAPS
FROM OBD0 TO OBD1
ECU repairs
CLICK HERE >>> OUR FACEBOOK SITE
81360091974
Old May 13, 2010 | 06:43 PM
CrXSibeast's Avatar
Its a 1990 acura integra, the ignition rotor was burned out and I replaced it and now it doesn't want to start it keeps back firing but I checked my timming and its still good
Old May 14, 2010 | 06:00 AM
CrXSibeast's Avatar
Old May 14, 2010 | 12:44 PM
Pull the rotor off and re-install it. Some of them can be put on backwards
and that will affect the timing, sending fire to the wrong place at the wrong time.-Bob
Old May 15, 2010 | 05:12 PM
CrXSibeast's Avatar
oh i did that and car started but only for 20-30 sec and then turns off, theres like no power, tried driving but wouldnt really go anywhere
Old May 15, 2010 | 06:02 PM
rangcrx's Avatar
engine building &best
i would try another distributor sounds like your ignitor is going.if it does not want to rev up then thats your problem
i love AUTOZONE
Old May 16, 2010 | 07:37 AM
CrXSibeast's Avatar
it barely revs up in idle until i floor it all the way and then i get some power but when i try to drive it wont go no where at all like 10 mph
Old May 16, 2010 | 07:41 AM
2TONECB7's Avatar
Y0uNG PiFF
i just had the same problem. check your ECU FUSE to c if its blown
USDM [H] PiMP
TR "Old Skool EF" Member #175
FT + UP TO 1000 ON TOP.. WAT U GOT??
TR police interceptor Member #01
