Need Advice On Sway Asap!!!
Just recently brought a 1999 honda civic ex and brought a jdm h22 swap . is there any way or advice on how i can somehow keep power steering and a/c .
1.Power steering is not needed on a small car...reasons in my shop forum articles...I took mine off years ago and made a lightweight block-off plate.
2.A/C...I would look for an A/C bracket that matches the block holes
on the new motor and your current A/C holes,....... maybe pull one off a junkyard car. Get the junkyard belt or write down the part number. Probably someone has done this before and posted it if you do a dogpile.com search.
Did the new motor come with the a/c bracket bolted to the block?
Does the belt line up OK on the pulleys?-Bob
