B20 vtec w/ a bottle ?
alright ima need help from yall ... my question is, will there be problems if i run nos to my b20? i've heard they dont recconmend boosting b20 cuz it has weak sleeves, that why i wanna look into how nos will affect my b20. thanks.
http://www.facebook.com/photo.php?pi...&id=1815553698
/http://www.facebook.com/photo.php?pid=319725&l=eb71a77f6d&id=1815553698
DUDE ! wheres my CIVIC ?
You can boost a b20 up to around 300whp safely tuned on gasoline. Yes the sleeves are weaker then those found in other smaller bore B series. But i've seen some make decent power. As far as spraying it it should be fine with supporting mods and TUNED by a reputable guy.
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
i have a b20 vtec on boost... runs hard as fuck, no probs...
im on stock everything on 10.5 lbs making around 300 give or take
The B20's Low Compression Is The Reason It Can Hold Up However I Wouldnt Reccomend U Revving The Hell Outta The Motor Because Then You Will Run Into Problems With These Weak Sleeves But Otherwise I Dnt See A Problem With A Wet 100 Shot
B20's are fine under boost...your b20vtec should have made more power than 300whp at 10.5lbs...what size turbo are you running?
Nitrous still needs to be actually tuned not just by jets but by computer too. I'd recommend turbo over nitrous though.
